Opinions Needed: OEM turbo choice for use on a stock D16Y8 engine
Old Nov 23, 2016 | 08:56 AM
EGUK's Avatar
Default Opinions Needed: OEM turbo choice for use on a stock D16Y8 engine
Struggling to pick a turbo for my stock d16y8 build.. not looking for huge power just good street setup that wont fall on its face before redline.
I have a few options to hand or off friends.
R32 GTR t25
TD04l 12t/14t/15t
and a random t3 with the following specs -
Turbine housing: A/R .63 with T3 flange.
Turbine wheel outlet 48mm, outer diameter 64.5mm
Compressor housing A/R=0.5
48 trim compressor; inducer 53mm, exducer 76.5mm
Any advice welcomed.
Old Nov 23, 2016 | 04:43 PM
2kdrift's Avatar
Default Re: Opinions Needed: OEM turbo choice for use on a stock D16Y8 engine
can you be a bit more specific as far as power goals...how much hp? stock rods?
stay away from ebay, and get a turbo that supports the power goals you are about to fill us in on
Old Nov 24, 2016 | 07:46 AM
EGUK's Avatar
The engine is stock.. power gals are limited by this so 220?
Old Nov 26, 2016 | 04:52 AM
wantboost's Avatar
Who is Mr Robot?
If you want a responsive DD that makes fairly linear torque use the following
GT1752S
T25
14B
Old Nov 26, 2016 | 06:32 AM
gabocastano's Avatar
Garrett 2056
nokehockey20
Jun 3, 2016 05:53 PM
jdm_vtec
Nov 17, 2006 03:37 PM
Project_SOHC_EX
Feb 12, 2006 07:29 AM
2old_honda
Apr 1, 2005 03:20 PM
DigitalFusion
Nov 12, 2003 08:52 AM
