Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 CRV Driver window won't go down.
Old Nov 2, 2016 | 07:43 AM
TheOrangeHatch's Avatar
Post 2000 CRV Driver window won't go down.
I searched the forums and couldn't find what I need. I have a 2000 CRV, all windows were working fine. One day going through the drive through at Wendy's I tried to roll my window down and no dice. I can press the switch down and right after I do I can hear and audible click, the same click that is made when you use the "auto-down" feature and the window gets all the way down and the switch clicks. I had the same thing happen on a 2001 CRV I had but traded it before I solved the problem. So for this one I bought a new regulator and motor, removed the door panel, and plugged the new motor up to verify that that was the problem. Still no dice. All relays and fuses are fine. Does anybody have any suggestions on what to do/check?
FlyingTSX
Oct 19, 2018 07:20 PM
Sweeteg
Oct 4, 2012 11:18 AM
EM1SON
Nov 16, 2009 04:35 AM
surferdude
Oct 17, 2008 03:56 PM
yee SERIOUS
Sep 1, 2006 06:06 PM
