HELP: driver side window stuck....
Old Sep 1, 2006 | 01:54 PM
yee SERIOUS's Avatar
Default HELP: driver side window stuck....
my driver side window is down...and it's stuck. it won't come back up. the passanger side still goes up and down though. i've checked my fuses and they're not blown. anyone know what could be wrong? i doubt that the motor just died on me?
it's a 2000 2dr gsr.
TIA
Old Sep 1, 2006 | 01:56 PM
HGZ's Avatar
HGZ
Default Re: HELP: driver side window stuck.... (undercoverdc2)
do you hear it trying to go up at least?? or is completely dead, no movement, sound, anything?
Old Sep 1, 2006 | 02:17 PM
lol i own a turbo car. i think i know to press the button up
anyways, it's not making any movement or sound. it went down normally.
Old Sep 1, 2006 | 02:24 PM
HGZ's Avatar
HGZ
Default Re: (undercoverdc2)
well if it isn't making any kind of movement or sound whether you press up or down, and the fuses look fine then i would suspect your window motor is bad, or perhaps maybe your 2000 gsr driver-side window switch fried while the pass.-side switch still works..??
i'm stumped.. hopefully someone else will have some insight for you.
Old Sep 1, 2006 | 03:58 PM
arghhhhhhhhhhhhh the switch is fine cause i can still control the passanger side. i'm wondering if it's the relay or the motor.
can someone verify that the passanger side has the same motor or relay so i can remove the passanger side to try it on the driver side?!
Old Sep 1, 2006 | 05:56 PM
Dogginator's Avatar
Daisy... Daisy...
Have you implemented a multimeter to confirm that the signal is reaching the motor? You can verify the switch output as well.
Old Sep 1, 2006 | 05:59 PM
how do i test it?
Old Sep 1, 2006 | 06:06 PM
Dogginator's Avatar
Daisy... Daisy...
That is easy to show and difficult to explain in just words. The Helm is a good guide for the troubleshooting. If you do not have one, search Google for "hondahookup manuals". Look at page 23-236.
girliehonda
Honda Civic (2001 - 2005)
10
Oct 16, 2016 03:32 PM
v-tecnition
Oct 6, 2008 01:19 PM
spd18
Jun 15, 2003 10:32 PM
dskny
Mar 26, 2003 04:23 PM
