Honda CR-V & Element 2WD & 4WD Element & CR-V
2nd Gen CRV tail gate switch issues and fix
Old Oct 29, 2016 | 12:52 PM
EJ8_Man's Avatar
Default 2nd Gen CRV tail gate switch issues and fix
Issues: Rear hatch is closed fully but the indicator light for the rear hatch is on. This prevents the keyless remote from locking the vehicle. Or the indicator light for the rear hatch flickers intermittantly while driving.
This is a complaint I see with second gen CRVs 2002-2006. I have a 2006 CRV. I believe this happened because a rubber sleeve fell off the switch causing it to not engage. Honda designed the tolerance for this component incorrectly.
Here is my solution for fixing it.
Crawl inside the trunk and close the hatch. Find where the hatch and switch make contact. Mark the location. Drill a hole and insert a screw in the hole. I used a 1/2 inch long panel screw from a junkyard Honda.
Here's my screw making contact with the switch with the hatch closed
Done
Old Oct 29, 2016 | 03:00 PM
TyGuy88's Avatar
Default Re: 2nd Gen CRV tail gate switch issues and fix
Another trick for this is slide a small piece of rubber hose over the switch. It's a little janky but most will never notice.
Old Oct 29, 2016 | 03:04 PM
EJ8_Man's Avatar
Excellent idea. Bypass the need for drilling. I like the hose idea over my solution
D21X
Dec 12, 2005 04:08 PM
X2BOARD
Apr 29, 2004 01:46 PM
B18CR-X
Apr 2, 2004 01:57 PM
spd18
Mar 7, 2003 04:19 PM
ILOVEGIRLS
Sep 29, 2002 12:17 PM
