Assistance needed: Identifying valvetrain components
Old Oct 28, 2016 | 11:09 AM
S2k@9K's Avatar
Default Assistance needed: Identifying valvetrain components
Hello,
I've acquired a bunch of parts recently and while most have matched up to what I was told they were. I am curious about the head. I was told it was an ITR head/Cams with Crower springs/retainers. The Cams turned out to be from a GSR. But, there has definitely has been some work done to the head.
What I know so far: PR3 cast, Year 2000, no green paint by distributor, port in valve chamber, dual springs
Questions; The valve springs look more like Supertechs to me?, The valves look like ITR? maybe aftermarket? ITR head that had the seats replaced with copper? or ported B16 head to fit the seats? (purpose?)
The pics/valves are of the intake side only. Are there any other ways I can identify, that I may be missing?
I hate to have to post this kind of thread, but, I know there are a lot of people on here that have dealt with this and can point out things rather quickly! Thanks.
Old Oct 28, 2016 | 02:14 PM
TheShodan's Avatar
Moderator
Default Re: Please help identify Head, valve springs etc....
I'll keep it at this thread here. It does not need to be posted in the other forums. Tech forums typically are viewed by those that go into different sections.
With that said, unless you can compare them with photos of other company's components that have clear identifying marks, it will be almost impossible to determine what they are without comparison on your end. However, you might get lucky. Doubtful, highly unlikely even... But possible.
Old Oct 28, 2016 | 02:56 PM
S2k@9K's Avatar
Default Re: Assistance needed: Identifying valvetrain components
Yeah, I figured it was a crapshoot on the valvetrain, being that I couldn't find any identifying marks. I would appreciate any help on the head though, from those who have had an ITR head in hand or one that the valve seats have been replaced on. If it looks like the ITR polish of the valve throat or not. Really, If it looks ok to use without any further work? I know this is difficult to tell over the internet, but, my next step will be to ship it off somewhere, as there are no decent local machine shops.
Old Oct 29, 2016 | 03:26 PM
TheShodan's Avatar
Moderator
Head is too dirty to see if the valve chamber has been manipulated as per Type R standards. Best bet is if you send it to a reliable machine shop, they'll do that "bowl work" for you anyway. Only the machine shop will be able to know for sure if the head is perfect.
But as an added measure, check those service marks at the end of the heads, and measure to see if it's been milled more than .030". If so, this head is no good.
Good luck to you.
Old Oct 29, 2016 | 06:50 PM
S2k@9K's Avatar
10-4. Thanks for the info!
cls55boost
Jul 23, 2007 03:20 PM
GapxGuy
Dec 11, 2002 06:35 AM
coasterlvr
Sep 11, 2001 08:11 AM
