92 civic dx - blown fuse 15 and speedometer issues
Old Oct 3, 2016 | 09:46 AM
ptrack's Avatar
Default 92 civic dx - blown fuse 15 and speedometer issues
Howdy.
My 92 civic dx sedan has some issues..My speedometer started jumping randomly a couple weeks ago. The problem stopped for a couple weeks and started up again .The speedometer failed the next day. At this point in time none of the gauges work,the turn signals dont work, I have to use the shift override to put the car in neutral because the shifter wont move out of park upon start up....After some research, I changed my no.15 fuse and everything went back to normal....However the fuse blew out in a very short time....I pulled the cluster out and there where no signs of damage, I also checked the wiring at the vss for continuity. Everything checked out just fine. I'm wondering if I need to replace the cluster or the vss. I've driven the car a little bit and it seems to be fine. However,I would like to fix the problem asap. Any help here would be appreciated.Thanks.
Old Oct 3, 2016 | 11:44 AM
Former User's Avatar
Default re: 92 civic dx - blown fuse 15 and speedometer issues
Individually unplug each component protected by fuse 15 to see which unplugged component prevents fuse 15 from blowing.
parisz47
Apr 11, 2017 05:02 AM
agustintorre
Sep 14, 2012 06:55 PM
biev
Jan 15, 2009 09:00 PM
