car turns off right after I turn it on
Old Sep 23, 2016 | 05:45 PM
Jvelez1216's Avatar
Default car turns off right after I turn it on
I have a 1992 eg hatch back with a d16z6 swap. The car use to run perfectly fine but after not turning it on for about a week now every time I turn it on it stays on for about 2 seconds but then it turns right back off the only way it stays on is if I give it gas to like 3 - 4K for about 10 seconds and while I do that the idle fluctuates but after that the idle is fine and it turns off fine for the rest of the day what can this be? I am using a P0B ecu If that has anything to do with it but I have always used that one thank you
Old Sep 23, 2016 | 07:53 PM
Former User's Avatar
Default Re: car turns off right after I turn it on
Post the CEL codes.
Old Sep 24, 2016 | 12:49 PM
Jvelez1216's Avatar
The car doesn't give me any but when so turn it on it runs for like 2 seconds and then the check engine light comes on and the car turns off
Old Sep 24, 2016 | 01:01 PM
When the engine stalls, don't switch the key to off. Instead, jump service connector to pull code.
Mikes2000civicsi
12
Oct 15, 2011 03:59 PM
tech410
29
Feb 21, 2011 05:10 AM
wazman
May 6, 2009 10:13 AM
-[95cxhatch]-
21
Apr 22, 2004 07:24 AM
-[95cxhatch]-
Jan 15, 2004 08:31 PM
