Honda/Acura Shift Pin "B!tch Pin" Removal; Alternative Method
Old Sep 20, 2016 | 01:11 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Honda/Acura Shift Pin "B!tch Pin" Removal; Alternative Method
Like most, I had some trouble removing the shift pin (bitch pin). I'm not a fan of the BFH method and I don't own an air hammer and Matco 6565 bit.
I used a C-clamp on my D-series transmission, but found it sloppy and cumbersome. It's also difficult to "balance" the setup as the screw is rotated.
I would just like to offer an alternative to the above solutions.
It's simply a ball joint separator instead of a clamp. I found I can't get a C-clamp to work with a B-series transmission, but the ball joint separator worked very well.
Here's the setup. (NOTE: Exhaust manifold/header is removed)
-Harbor Freight 3/4" ball joint separator (99849) ~$20
-Two allen bits (from a bit kit).
-Socket and wrench.
-19mm wrench (a larger mm wrench would have worked better).
The wrench has to be used because the prongs of the BJS are too wide to rest level on the shift lever. A larger wrench 22mm or 24mm would have worked much better. 19mm was the largest I had.
Use the smaller allen bit, tip should fit inside the pin, to start the pressing process.
I had to do this because the pin wouldn't have past by the prong on the BJS. I could have started the entire process like this or used a larger wrench as posted earlier.
The second allen bit, about the size of the shift pin, needs to be used to press the pin through entirely.
The overall benefit is the stability of the setup. The pressing result isn't part of the pressing force like with a C-clamp. So the parts don't want to turn as the screw is turned. Hopefully some will find this useful.
eH.
Old Sep 20, 2016 | 01:40 PM
Former User's Avatar
Default Re: Honda/Acura Shift Pin "B!tch Pin" Removal; Alternative Method
Nice. I'll give this method a try next time.
Old Sep 20, 2016 | 02:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Very nice! I will remember this for next go around.
Old Sep 20, 2016 | 04:00 PM
98civdx's Avatar
Master Detailer
Looks like a perfect method for the guys laying on the ground without **** for room to swing a hammer.
Old Sep 20, 2016 | 08:52 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
That's it, exactly.
eH.
Old Sep 20, 2016 | 10:03 PM
eghatch9295's Avatar
Stancetard Hate Monger
not bad. ac comp bolt and or punch has always worked for me, but alternative methods are always useful.
Old Sep 20, 2016 | 10:53 PM
testify's Avatar
On vacation
Hammer and a punch is easy once you're used to it.
Old Sep 21, 2016 | 01:10 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Been there, done that. Air hammer reduces the time for this exercise to 5 seconds.
Old Sep 21, 2016 | 10:24 PM
StevoDVS's Avatar
nice move...
Old Sep 22, 2016 | 06:44 AM
tony_2018's Avatar
Fish Twig
Good ****, I'll give it a try during installation.
Bright13
Honda S2000
Oct 30, 2011 03:10 PM
db8int3gra
Dec 11, 2008 06:52 AM
pre1udekid
Jul 12, 2004 03:49 PM
93MR2Turbo
Apr 5, 2004 11:46 PM
dontcare61776
Jun 11, 2002 06:09 AM
