Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Lost TDC, need help to reestablish
Old Sep 11, 2016 | 01:07 PM
pcconway's Avatar
Default Lost TDC, need help to reestablish
I was replacing the timing belt and decided to to the front main seal while I was in there. Everything looked great. After successfully replacing the seal and reinstalling the timing belt, I got impatient and with a wrench moved the crank checking for interference, just to make sure. Unfortunately I had not yet pulled the pin on the tensioner and the belt skipped a few grooves. I've lost TDC on the crank and the only way I can figure to restore is to alternately and manually advance the cams, and then the crankshaft one at a time until I get the crank back to TDC. I can't figure a good way to move the crank counter clockwise. All advice gladly welcome. -Pete
Never mind.. I got the crank bolt in without advancing and was able to gently ease it back before the bolt started to loosen.. sorry to bother..
Randysi
12
Oct 20, 2011 03:00 AM
m00nr0ck Si
May 31, 2008 07:22 AM
Apple-Juice
16
Mar 28, 2004 03:34 AM
Muckman
Sep 15, 2003 05:34 PM
vtec69
Jan 16, 2003 08:37 AM
