OBD2 to OBD1 conversion
Old Sep 9, 2016 | 05:48 AM
lxrd_vtec's Avatar
Icon2 OBD2 to OBD1 conversion
Sorry to bring a thread back from the dead, but do any of you guys know if an OBD1 engine harness will work with an OBD2 motor? I have a 00 (OBD2)GSR swapped eg and I have done the step down conversion to OBD1 but Im considering ordering another engine harness mainly because the guy that did it for me did a hack job that leaves me a bit skeptical. Or would it be better to order another obd2 harness? Thanks guys
Old Sep 9, 2016 | 06:01 AM
mk378's Avatar
Default Re: OBD2 to OBD1 conversion?
You would use an OBDIIb engine harness to match your '00 dash harness. The only part of your setup that is OBD1 is the ECU itself, and it is adapted at the ECU plugs.
Old Sep 10, 2016 | 02:26 PM
HondaPartsHero's Avatar
Technical Hero
What's your year make and model and what ECU will you be using?
Old Sep 13, 2016 | 12:19 PM
lxrd_vtec's Avatar
Should've said this earlier, but it is a 00 OBD2b GSR motor in a 93 Civic DX hatch shell. I am currently running a p28 with a GSR basemap.
Old Sep 13, 2016 | 01:40 PM
tony_2018's Avatar
Fish Twig
Depends on what type of injectors, distributor, and alternator you have. If you converted everything to obd1 than find an obd1 engine harness. You'll have to give us more details. It be a big waste if you got the wrong harness and had to do more conversions, which leads to more bad hack jobs.
Old Sep 18, 2016 | 01:06 PM
lxrd_vtec's Avatar
As I know my distributor is OBD1 , as for the alternator and injectors I'm not a hundred percent positive. I think they're the injectors/alternator that came out of my GSR so they should be converted to run obd1. Tomorrow I'll go out and double verify on the alternator.
Old Sep 18, 2016 | 03:00 PM
tony_2018's Avatar
Fish Twig
Man, its gonna be hard to fine a good condition obd1 integra harness, or an obd1 civic harness.
novaslean
Apr 14, 2010 09:23 AM
roachsboosted16
Nov 16, 2007 10:11 PM
NOman0608
Jul 26, 2007 10:28 AM
stehigs321
Feb 21, 2004 12:03 PM
boostedEJ2
Jun 3, 2003 07:30 AM
