hondata s300 extreme lean on decel
Old Sep 2, 2016 | 05:44 AM
civicb1812345's Avatar
Default hondata s300 extreme lean on decel
I have a b18c1 boosted with precision 660cc injectors and a 57 trim on e85. I have started the baseman and I can get it to idle right afr and rev to 3k or so. But if I tap the gas idling it goes max lean coming back down from rpms. And decel goes max lean as well and backfires badly.
Old Sep 2, 2016 | 10:34 AM
PGHintegra's Avatar
Default Re: hondata s300 extreme lean on decel
It's supposed to be lean on decel. It will be driving as well. If you keep injecting fuel on decel you wouldn't be able to engine brake and what not and that extra fuel would pop and backfire in your exhaust
Old Sep 2, 2016 | 06:39 PM
pogeeboy27's Avatar
Try adding some timing in the decel areas of your timing map to get rid of backfires.
Old Sep 3, 2016 | 04:28 AM
spAdam's Avatar
Loved
Community Favorite
Look at your data and see if you are coming out of fuel cut on decel. Off throttle fueling will cause bucking and backfiring, and can cause high exhaust temps too. Adjust your fuel cut MAP threshold as needed to keep it activated while coasting.
pavilionlivin
Engine Management and Tuning
Dec 25, 2009 09:55 AM
kaj
Feb 6, 2006 07:52 PM
D@nnY
Jan 11, 2004 07:57 AM
mafay2
10
Sep 23, 2003 09:47 PM
TriK
Aug 20, 2002 08:20 PM
