pull harder at mid throtle than at full ?
Old Aug 20, 2002 | 05:00 AM
TriK's Avatar
Default pull harder at mid throtle than at full ?
my car are doiing that..
i fell that it pull more and tire are more easy to spinn at mid throtle
have a idea why?
Old Aug 20, 2002 | 05:42 AM
X2BOARD's Avatar
Default Re: pull harder at mid throtle than at full ? (TriK)
Sounds like air/fuel. What's your fuel setup right now ?
Old Aug 20, 2002 | 05:51 AM
TriK's Avatar
Default Re: pull harder at mid throtle than at full ? (X2BOARD)
map 3 bar gm
piggyback with sur injector controler with 2X550cc before the throtle
fuel pump nipodenso toyota supra tt 255lph
i know it"s not the best.. this is corect for now.. i a couple of month il take the ems
like that i do 12.888 @ 108.516 mph at mid throtle
Old Aug 20, 2002 | 06:15 AM
zcivic91's Avatar
sounds to me alil richy!!
Old Aug 20, 2002 | 06:20 AM
TriK's Avatar
Default Re: pull harder at mid throtle than at full ? (zcivic91)
possible!
think it's time to tune a little bit
Old Aug 20, 2002 | 07:34 AM
boosted hybrid's Avatar
Yeah sounds like possibly a bit to rich, but also timing issue. You might have timing backed out up top to much...although you dont have a standalone to do that. I would have to go with to rich up top, lean it out and you should feel some power gain.
Old Aug 20, 2002 | 08:48 AM
sgT's Avatar
sgT
Default Re: pull harder at mid throtle than at full ? (boosted hybrid)
I would think too lean.
Is there a lot of black smoke when you are on the gas?
He doesnt really have enough fuel unless he has an FMU that he forgot to mention.
Old Aug 20, 2002 | 09:57 AM
JM Performance's Avatar
Default Re: pull harder at mid throtle than at full ? (sgT)
how would too rich up top effect how throttle position effect performance. If hes using an AIC it usualy either controls by boost or by boost and rpm, not throttle position.
are you sure its just not a perception thing? people have asked about this before, and figured that its most likely that you expect to go faster full throttle.
Old Aug 20, 2002 | 10:07 AM
X2BOARD's Avatar
Default Re: pull harder at mid throtle than at full ? (00SilverLS)
I experience this problem with my car now (unboosted), but it does not continue in the higher rpm band. Then again, my car is waaay out of tune and using the wrong ECU for the setup... (and it runs RICH)
Old Aug 20, 2002 | 10:12 AM
roadrunner's Avatar
Normal ignition maps give more advance at part throttle (light load) than at full throttle (fully loaded)... this may still apply in your case, rich or not...
Old Aug 20, 2002 | 10:20 AM
ion_four's Avatar
Default Re: pull harder at mid throtle than at full ? (roadrunner)
I experience the same problem in my car...I'm running 450cc's and a little circuit to scale the MAP output...it works great, the only prob is that I don't have a downpipe at all, so my oxygen sensor is gettinga really flakey reading, so if I want the car to idle at all I have to make it run really rich up top. I'd have to conclude that you are running extremely rich, as well. my car pulls hard at about 75-90% throttle, but starts to bog and jerk a bit at WOT...it'll be worked out when I get the DP on, though...
austrian type-R's Avatar
on lower rpms the engine pulls harder on part throttle than on WOT. Reson is of the big intake runners and the big throttle. The turbo produce no or only minor power and there is a very low air flow on WOT. With only 50% throttle you decrease the intake diameter and air is speeding up, therefore the combustion cambers are getting more air and is pulling harder.
This has nothing to do with 1/f mixture. It has something to do with a n/a engine style.
Old Aug 20, 2002 | 08:20 PM
TriK's Avatar
Default Re: pull harder at mid throtle than at full ? (austrian type-R)
thanks
civicb1812345
Engine Management and Tuning
Sep 3, 2016 04:28 AM
SoSlo
Jun 10, 2005 01:02 AM
SOHC_MShue
Mar 1, 2005 05:42 AM
D@nnY
Jan 11, 2004 07:57 AM
TypeR1558
Feb 11, 2002 04:06 PM
