How to bypass check engine light?!
Old Aug 27, 2016 | 06:58 AM
Dahhhbeed's Avatar
Default How to bypass check engine light?!
So my 93 civic has a code 22 being thrown and i need to smog my car so i need to take off the check engine light to pass, anyone know how? Help!! This is just to pass cause im low on funds to fix it rn .
Old Aug 27, 2016 | 07:04 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: How to bypass check engine light?!
The CEL needs to be functional.
They check the CEL upon start of the car, it needs to come on and turn off in order to show it works.
Old Aug 27, 2016 | 07:13 AM
mk378's Avatar
That is usually an easy code to fix, often for zero dollars.
The code is for the VTEC pressure switch. First consider does the engine even have VTEC, or do you have a mis-matched situation of VTEC ECU on a non-VTEC car? If there is a VTEC solenoid and pressure switch, make sure it is plugged in.
Old Aug 27, 2016 | 07:43 AM
Former User's Avatar
Check whether your engine oil is low, and clean the screen in the VTEC solenoid gasket.
Old Aug 27, 2016 | 07:50 AM
Dahhhbeed's Avatar
its a d16z6 vtec and it is plugged it the whole solenoid is brand new, so maybe a connector problem?? Like the grey plug green plug?
Old Aug 27, 2016 | 07:51 AM
Dahhhbeed's Avatar
aw damn thats right haha
Dahhhbeed's Avatar
just changed my oil yesterday but havent clean the gasket in the solenoid will do it rn and let u know if it works.
Old Aug 27, 2016 | 07:53 AM
Did you also replace the oil filter?
Old Aug 27, 2016 | 07:58 AM
Dahhhbeed's Avatar
sure did!
Old Aug 27, 2016 | 08:00 AM
Dahhhbeed's Avatar
Brand new from japan
Old Aug 27, 2016 | 08:22 AM
FactionR's Avatar
How To: Run a JDM Vtec Solenoid on a USDM ECU | ClubCivic.com - Your Online Civic Community
This will allow you to bypass the vtec oil pressure switch to get rid of the CEL. However the switch itself may be bad or you may have a larger underlying issue with oil pressure which is big problem.
Old Aug 27, 2016 | 08:45 AM
Dahhhbeed's Avatar
god forbid but say it is an oil pressure problem, how can this be fixed?
Old Aug 27, 2016 | 09:08 AM
FactionR's Avatar
A good cleaning (the likely issue would be a blockage somewhere) a new pump and switching oil thickness to a viscosity that restores proper pressure.
Majority of the time though its always the simple things that cause issues. In other words my money would be on a wiring/pressure switch issue.
Old Aug 27, 2016 | 09:38 AM
Dahhhbeed's Avatar
how does one give it a good cleaning? And which pump exactly is the one you speak of?
I feel like it could be wiring as well, and the solenoid is brand new so it cant be the pressure switch if its brand new, so maybe the other green switch that plugs into the pressure switch along with wiring?
Old Aug 27, 2016 | 03:08 PM
K20A3F00L's Avatar
This is a simple easy vid on how to clean it and put new gaskets on, also shows how to test the solenoid itself.
EF-ingB16
Nov 4, 2011 05:40 PM
mtg4gen
Apr 9, 2007 09:02 PM
Capt. Singlecam
Feb 1, 2007 05:56 PM
scythemk
Jan 29, 2006 10:10 AM
jbscivichb92
Aug 16, 2004 05:13 AM
