Boost problem!
Hi guys!
i have a boost problem, I have 5 psi in first and in second 8 psi and full boost 20 psi in 3-4-5 gear. Full boost is around 7k rpm and i have a first gen 6765 precision, no shaft play at all on the turbo!
the powerband is very high it begins at almost 7k rpm also. It made 549 whp at 20 psi the car has power but nut at the good range!!
Setup is; GE 84mm block,arias piston,manley rods,SIR head,ferrea valves,bisimoto springs/retainers,crower stage 2 turbo cams,edelbrock intake, skunk 2 70mm tb, id 1000c, 6765 precision, 46 mm wastegate
Actually that's pretty good. You didn't want all 20psi the 1st couple of gears anyway on a turbo that large.
Second, the engine won't make that much exhaust energy for something that big in the lower gears any way, so, again, not that bad.
Third, tuner could have made the car do that with BBG (possibly) or other devices to assist with traction control.
Changing blocks is a lot, sorry to say..... Even if at similar compression. Someone asked about the boost controller..... and the answer that is....
im not familiar with how quickly that turbo would spool on just a spring, but it sounds like it may make sense that its taking a little time in 3rd gear to build up the additional charge of 12 more psi. while I haven't run boost by gear I know that running off just the spring once you've spooled you don't have to wait in any further gears..
Relax... We're just making sure all bases are covered, and all I the same page, here. You'd be surprised on how purple forget, the devil is in the details. We weren't there when it happened, so you have to give the entire story ;-).
It may not be the solenoid itself but how it is set up with the new block. What is your tuner saying about this so far?
There's a lot more between the turbo and the solenoid.
- vacuum lines (could be collapsing due to length or location)
- damaged vacuum lines or fittings.
- different vacuum sources from one motor to the other
- settings from the software to the solenoid may have changed (highly unlikely but best to check)
-new location of solenoid (if any) since it is a MAC
- change of timing in the software between old and new block. (Some things did change in the tune, especially if a new block) which goes back to software settings.
C'mon. I can't do all of this for ya.
You have a lot to look through together.
mrbsponge
Jun 27, 2005 06:29 AM
