Boost problem!
Old Aug 22, 2016 | 03:06 PM
Boosted67's Avatar
Default Boost problem!
Hi guys!
i have a boost problem, I have 5 psi in first and in second 8 psi and full boost 20 psi in 3-4-5 gear. Full boost is around 7k rpm and i have a first gen 6765 precision, no shaft play at all on the turbo!
the powerband is very high it begins at almost 7k rpm also. It made 549 whp at 20 psi the car has power but nut at the good range!!
Setup is; GE 84mm block,arias piston,manley rods,SIR head,ferrea valves,bisimoto springs/retainers,crower stage 2 turbo cams,edelbrock intake, skunk 2 70mm tb, id 1000c, 6765 precision, 46 mm wastegate
Old Aug 22, 2016 | 05:03 PM
TheShodan's Avatar
Moderator
Default Re: Boost problem!
Actually that's pretty good. You didn't want all 20psi the 1st couple of gears anyway on a turbo that large.
Second, the engine won't make that much exhaust energy for something that big in the lower gears any way, so, again, not that bad.
Third, tuner could have made the car do that with BBG (possibly) or other devices to assist with traction control.
Old Aug 22, 2016 | 05:06 PM
wantboost's Avatar
Who is Mr Robot?
A turbo that big won't spool any sooner on a low displacement engine
Old Aug 23, 2016 | 02:28 AM
Boosted67's Avatar
Yeah i know the turbo is not that small, but before with my stock sleeve engine i hit the boost much sooner like at 5500 rpm and ive change nothing except the block!!
Old Aug 23, 2016 | 03:50 AM
Fishy_hondaman's Avatar
Wats ur boost controller
Old Aug 23, 2016 | 06:49 AM
TheShodan's Avatar
Moderator
Changing blocks is a lot, sorry to say..... Even if at similar compression. Someone asked about the boost controller..... and the answer that is....
Old Aug 23, 2016 | 08:58 AM
Boosted67's Avatar
Boost controller is 3 way Speed Factory...with PWM on Neptune
Old Aug 23, 2016 | 09:39 AM
TheShodan's Avatar
Moderator
So, basically, a MAC 3-port. Gotcha.
Old Aug 23, 2016 | 11:22 AM
Boosted67's Avatar
Maybe it's the controller my problem...because on my previous block i didnt have any i was running on the wastegate spring at 15 psi
Old Aug 24, 2016 | 07:23 AM
boostjunkie757's Avatar
im not familiar with how quickly that turbo would spool on just a spring, but it sounds like it may make sense that its taking a little time in 3rd gear to build up the additional charge of 12 more psi. while I haven't run boost by gear I know that running off just the spring once you've spooled you don't have to wait in any further gears..
Old Aug 24, 2016 | 08:59 AM
TheShodan's Avatar
Moderator
Maybe, but I doubt it. was this same overly large turbo used on your previous block?
Old Aug 25, 2016 | 03:15 PM
Boosted67's Avatar
Yess it's the same turbo!
Old Aug 25, 2016 | 08:26 PM
TheShodan's Avatar
Moderator
Relax... We're just making sure all bases are covered, and all I the same page, here. You'd be surprised on how purple forget, the devil is in the details. We weren't there when it happened, so you have to give the entire story ;-).
It may not be the solenoid itself but how it is set up with the new block. What is your tuner saying about this so far?
Old Aug 26, 2016 | 04:44 AM
Boosted67's Avatar
I'm relax ....The tuner doubt the turbo...we will dyno it again really soon and will keep you update.
Old Aug 26, 2016 | 07:04 AM
TheShodan's Avatar
Moderator
There's a lot more between the turbo and the solenoid.
- vacuum lines (could be collapsing due to length or location)
- damaged vacuum lines or fittings.
- different vacuum sources from one motor to the other
- settings from the software to the solenoid may have changed (highly unlikely but best to check)
-new location of solenoid (if any) since it is a MAC
- change of timing in the software between old and new block. (Some things did change in the tune, especially if a new block) which goes back to software settings.
C'mon. I can't do all of this for ya.
You have a lot to look through together.
BlownBlackSi
Nov 7, 2005 08:28 PM
hondaimport99
Jul 30, 2005 07:17 AM
slwazgsr
Jun 23, 2003 03:45 AM
maxim
Feb 14, 2002 01:47 PM
