97 Ek Coupe Speedo problem
Old Aug 18, 2016 | 01:17 PM
DohcVtec77's Avatar
Default 97 Ek Coupe Speedo problem
I have a 97 ex coupe with a b16a2 swap and for some reason I can not get the speedo to work.. I have replaced the transmission speed sensor that took away my engine light but my speedo still doesn't work. I've also replaced all the wiring in the back of the cluster as well as swapping another cluster that I pulled from a junkyard... Maybe the new cluster didn't work either? All my other guages read fine except my speedo. Any help would be appreciated thanks!
Old Aug 18, 2016 | 03:21 PM
slomofo's Avatar
GDD Member
Default Re: 97 Ek Coupe Speedo problem
Honda never made an EK coupe, so I think maybe you should come back when you've figured out what type of car you have.
Old Aug 18, 2016 | 03:25 PM
Former User's Avatar
CEL code 17 thrown?
Old Aug 18, 2016 | 07:13 PM
DohcVtec77's Avatar
Originally Posted by RonJ
CEL code 17 thrown?
it's an ex with a b16 swap but no engine light is on Vtec works as well
Old Aug 18, 2016 | 07:43 PM
Maybe the CEL doesn't work because the previous owner removed it.
Old Aug 18, 2016 | 09:43 PM
DohcVtec77's Avatar
CEL works fine I'm really confused
Old Aug 18, 2016 | 10:07 PM
Unplug the VSS and check for moisture inside and corrosion of the pins.
mehrio
15
Apr 14, 2013 08:45 PM
ShelbyX3
Apr 4, 2008 09:53 AM
JDM Dylan
14
Mar 5, 2008 09:11 PM
bluecal
Jan 5, 2007 12:40 AM
Xtian8
14
Jul 28, 2005 09:00 PM
