Holset HX35 compressor vband flange
Old Jul 29, 2016 | 09:33 AM
NWDyno's Avatar
Default Holset HX35 compressor vband flange
Hey guys. I am looking for the vband flange (and clamp) for the compressor outlet on a Holset HX35. I know Dodge makes a cast aluminum elbow piece beings the turbo is from the Cummins, and I figured I could easily find just the compressor vband flange and clamp but having a hard time. I know I can get the cast aluminum elbow and cut the flange off, but thought I would ask before I find another route. Thank you.
hx35/hx4/s300 turbos are all the same with respect to this compressor outlet flange...just cant find the darn thing in aluminum.
Old Jul 29, 2016 | 09:43 AM
NWDyno's Avatar
Default Re: Holset HX35 compressor vband flange
guess I need this but in aluminum
Stainless Diesel S300 V-Band Compressor Outlet Flange SD-S300CVOF
Old Jul 29, 2016 | 10:43 AM
Dark_Teg's Avatar
My V-band compressor housing is made of stainless steel. Aluminum would melt if used for a compressor housing.
Old Jul 29, 2016 | 10:51 AM
NWDyno's Avatar
Weird....every single turbo I have used has an aluminum compressor housing and steel turbine. What turbo do you have that has a steel compressor housing?
Old Jul 29, 2016 | 11:53 AM
2kdrift's Avatar
x2, and no compressor housing does not get nearly as hot as turbine housing so it does not get anywhere near melting point
Old Jul 29, 2016 | 07:02 PM
B and B's Avatar
Loved
Community Favorite
Lol, he was just mixing up the two, no doubt.
Man...vband **** is priced on a structure similar to eyeglasses...Ripoffs abound
Old Jul 29, 2016 | 09:20 PM
TheShodan's Avatar
Moderator
Not for when you want the quality ones that don't warp after 2-3 times attached.
It's the turbo world..man up, soldier. (Or reach into that pocket, whichever analogy you choose) ;-)
Old Jul 29, 2016 | 11:24 PM
TravisBiggie's Avatar
thats what you want.
my buddy is using a ebay 2.5" ebay vband with his hx35 outlet, it seems to work, but idk?
I have a hx35/40 sitting here, haven't decided if i'm shaving the lip off, or use the 2.5" if it works on my buddies car. its done, just not tuned yet.
Old Jul 30, 2016 | 06:41 AM
NWDyno's Avatar
Thank you. I will see if I can find a 2.5 vband laying around, see how well it matches up. Beings its a Dodge turbo, I assumed its was some odd/OEM only size
Old Jul 30, 2016 | 11:50 AM
TheShodan's Avatar
Moderator
Different aluminum grades have different flash points of melting. So we can all drop this semantic bickering now..
Find a flange or don't use it..you'll be fine
Old Jul 30, 2016 | 12:22 PM
NWDyno's Avatar
Thanks a bunch. Not mine, it's a customers car.
Old Jul 30, 2016 | 03:01 PM
I forgot to mention he put a metal o ring inside of the outlet of the compressor housing, but I don't think that is going to help anything since the seal of the vband seals on the flange itself.
Old Jul 30, 2016 | 05:55 PM
NWDyno's Avatar
Oh ok, thank you for the info. I am going to dig for a flange and try it out!
NWDyno
Welding / Fabrication
Jul 29, 2016 10:20 AM
GPoodle
Dec 9, 2003 10:57 AM
johnisenglish
Oct 28, 2002 06:40 PM
CovertFI
Jun 26, 2002 10:15 AM
