Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Accord Drain Tube Under Engine
Old Jul 26, 2016 | 02:54 PM
austinjack's Avatar
Default 2005 Accord Drain Tube Under Engine
I have a 2005 Honda Accord 4 door sedan. There is a small pool of fluid (not water but I am not sure if it is oil or another engine fluid) on the ground under the center of the engine. I felt above the pool & there is the open end of a rubber tube maybe a half inch across. There is fluid on the inside the tube that I can feel.
Does anyone know what I am talking about? I am trying to determine if the fluid is coming from that tube & if it is what is it & can I fix it or need to fix it. Any help would be appreciated. Thanks
Old Jul 26, 2016 | 04:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2005 Accord Drain Tube Under Engine
The drain tube under the car is for the A/C condenser, which would be water that drains from it. If you ran the A/C for a while, you normally will see a pool of water on the ground after you park it for a while.
Old Jul 27, 2016 | 03:46 PM
austinjack's Avatar
Thank you. I think the water on the ground had mixed with whatever else was there making me think it was not water.
DoubleDoobie420
Jul 18, 2017 05:42 AM
sifumoob
Dec 2, 2014 02:45 PM
pstevens90
Oct 25, 2014 08:30 AM
bdstad
Nov 2, 2012 06:27 PM
oddlaww
Sep 25, 2008 06:54 AM
