Help! Broken vehicle speed sensor
Old Jul 21, 2016 | 07:55 PM
streetracerjoey210's Avatar
Default Help! Broken vehicle speed sensor
So long story short, my speedometer went out on my em1
ordered new replacement one. Seems like a strait forward install but not so. Removed the 10mm bolt and was trying to pull sensor
well the unthinkable happened the sensor snapped off and leaving a portion still mounted in the transmission. My question is what are you're options on how to extract the left over damaged sensor.
It will not pull out..
any input please
Old Jul 22, 2016 | 06:21 AM
tony_2018's Avatar
Fish Twig
Default Re: Help! Broken vehicle speed sensor
You'll have to be creative with this one and hope to god the tidbits don't damage your tranny in any way.
Old Jul 22, 2016 | 08:34 AM
Former User's Avatar
What convinced you that a bad VSS caused your speedometer to stop working?
Post clear pictures of broken VSS in transmission.
Old Jul 22, 2016 | 08:52 AM
testify's Avatar
On vacation
Take a metal rod, put some epoxy on the end, stick it in the hole so it bonds to the VSS, then pull it out.
Old Jul 22, 2016 | 07:34 PM
Well, yes speedodm stopped working,
its out with some effort I had to chip away carefully with a flat head screwdriver finally broke it in four pieces, came right out "piece of ****"
its out and new one in and we'll still don't work ?? I know cluster works because before swap it was working
Old Jul 22, 2016 | 07:49 PM
testify's Avatar
On vacation
Maybe the gear in the transmission the drives the VSS is the problem.
Old Jul 22, 2016 | 07:55 PM
Or just maybe the VSS was never the problem because no diagnostic tests were done?
Think it's the engine harness issue, 97 civic hatch using the wire harness for a 99 b16a2 only two plug harness, looking for a ex 96-98 harness got the car this ways it's going to be a work in process
Old Jul 22, 2016 | 07:58 PM
Mixing OBD2a and OBD2b harnesses is risky, but do some diagnostic tests rather than throwing parts at the problem. Turn your VSS wild goose chase into a learning moment.
Old Jul 22, 2016 | 08:02 PM
What's the first step check for signal to sensor ? I.e. Voltage, ground ?
Old Jul 22, 2016 | 08:04 PM
Start here: Is CEL code 17 thrown?
Old Jul 24, 2016 | 08:02 AM
tony_2018's Avatar
Fish Twig
any input please
Gotta love reading **** like this.
Freckles
Aug 20, 2012 10:30 PM
Polak69pl
Jan 11, 2006 10:14 AM
Lucky_Smurf
Apr 20, 2005 12:22 PM
dee38655
Jan 26, 2005 07:01 AM
