New AC compressor - not cold AC
1998 Civic LX - A/C Compressor Clutch Noise (Only when disengaged)
Friends and Neighbors,
{1998 Honda Civic LX 1.6 SOHC 230,000 miles}
Over the past year or so, my A/C compressor has been making noise ONLY when disengaged. It sounds like a slight rubbing noise. When I turn the air conditioning on, the noise goes away.
The A/C system is at the correct pressure, although about two summers ago I over charged it and maybe damage was done to it at that time. It is now at the correct pressure and in the summer it blows cold air no problem.
I'm wondering if the ac compressor clutch is going bad. I do a lot of highway miles on my car (3,000mi/mo), so whatever is wearing out, I'm wearing it out more.
What could the problem be? Should I deal with it if it "aint broke?" And finally...Should i disconnect the belt to the a/c compressor while I'm not using it in the winter to preserve its life?
Re: 1998 Civic LX - A/C Compressor Clutch Noise (Only when disengaged)
Can you post a video of the noise?
Use a feeler gauge to measure the clearance between the armature plate and pulley. Is gap even all around?
Possibly the compressor bearing. A bad compressor bearing would usually increase in noise when compressor is engaged. However, I replaced my car's a/c compressor bearing a few months ago and noise was present while compressor was disengaged and made less noise when engaged. I pulled the bearing/clutch assembly from a junkyard..pretty simple replacement. Need to lower engine though to gain full access to a/c compressor.
Here's a link to a video:
http://youtu.be/Uumnxzj37k4
Inspect clutch when pulley has been removed.
It's possible to replace only the bearing pressed into the pulley. Sears hardware stores may have the bearing.
Note that it is possible to do the job without removing the compressor refrigerant lines.
Yea, the pulley is as loose as it can be.
Meaning, the bearing is bad, correct?
Ill need the ac clutch holding tool. Any other tools I'll need? I plan to do the job when it's warmer outside and I plan on leaving the refrigerant lines on.
Thanks for your help thus far. I got the A/C compressor clutch and bearing off without major issue. Bearing is bad, shaft is good. But compressor unit doesnt look too good. Not sure what it should look like, and if this is ok.
I'll also post a video.
A/C Compressor with bearing and pulley removed.
Here is a video, although the picture is quite clear.
If it looks Ok, I'll be purchasing this:
I just realized that what's rotted is the field coil, and that it comes with clutch kit.
So, I will go ahead and purchase the kit and go for the install!
My last question fro now: How do I press the new bearing in!? The instructions mention a "hub assembly guide attachment," which I dont think ill be able to get my hands on. Is there a type of press i need to rent at autozone? I've never used a press!
Looks like the bearing separated from the pulley, so after you remove the coil, carefully remove the bearing. Don't damage the shaft.
Use a socket to tap the new bearing into the pulley. I think you can also use a socket to tap the pulley+bearing onto the shaft.
Be sure to shim the armature plate.
My plan right now is to order the shim set from honda because I cant find washers thin enough to use as shims.
Any thoughts on why it sits slightly uneven? And whether the performance would be off if I shimmed it a bit more than what the specs call for?
And lastly if there are any suggestions to where I night find washers thin enough to use as shims!
Call AutoZone or the Honda dealer about shims.
The unevenness suggests that the armature plate is not seated flat on the shaft. Please post pictures.
Ladies and Gentlemen,
Thanks for all your help. But I aborted mission yesterday.
Everything was in place. I ordered the shims from Honda and was putting them in, when i noticed the bearing was wobbly. I realized that the replacement pulley with bearing installed was not sitting properly with the snap ring in place. in other words, I had to press the bearing in to the point where it would seem to be off the track and became wobbly.
Returned the kit to Autozone and got my money back.
Now, I think I'd like to swap out the whole a/c compressor assembly. I know I'l have to discharge the system, replace the unit, pull a vacuum and charge it up again.
I'm concerned about oiling up the new a/c compressor. Should I get a pre oiled one? Also, do I need to replace anything else?
Thanks!
Thanks!
Buying the clutch kit from Honda might be a cheaper and easier route.
Shop around.
For example:
Majestic Honda
38900-P2E-A01
CLUTCH SET, COMPRESSOR
$167.64
Shop around.
For example:
Majestic Honda
38900-P2E-A01
$167.64
Majestic Honda is selling CLUTCH SET for 167.64 and COIL SET for 78.65. Both of which I need. I can definitely get the compressor and drier for less than that.
I'm also concerned that even with the components from honda, I'd have to face uneven scraping of the armature plate.
OKAY! I'm back in business. I went ahead and replaced the compressor and dryer. At first it wasn't holding a vacuum, so I changed the o-rings again and lubed them well with PAG oil. It held a vacuum over night.
I charged up the system with a 22oz can of r-134 (so I wouldn't have to weigh anything (which I'm aware I may get flack for).
A/C is working! Vacuum pulled the initial r-134, and clutch kicked in and pulled the rest.
Manifold gauges read:
When A/C off:
Low -78 psi
High - 100 psi
Clutch on:
Low - 26
High - 170
I know I wouldn't have overcharged the system, but do these numbers seem ok?
When A/C off:
Low -78 psi
High - 100 psi
Clutch on:
Low - 26
High - 170
Old Fart
Low side pressure seems a little high,, [when "A/C on"] or not enough of a diff. between off and on, how is vent temp.?
I suspect bad expansion valve. 94
The vent temp is cold, but I feel it could be colder. I don't think the system has enough refrigerant because the whole 22oz can wasn't sucked into the system. I am afraid to overcharge, since if done t in the past.
Could the difference in on and off be due to low r134a?
