95 del sol d16z6 - water pump looks weird
Old Jul 21, 2016 | 10:15 AM
trailblazer's Avatar
Default 95 del sol d16z6 - water pump looks weird
any idea whats going on here?? this seems to be a 1995 del sol vtec model.. serial number is JHMEH6268SS003902 i never checked
Old Jul 21, 2016 | 10:39 AM
Former User's Avatar
Default Re: 95 del sol d16z6 - water pump looks weird
Haha. That's a jerry-rigged timing belt cover with the water pump pulley protruding through a cut hole. Are you driving this car?
Stock D16Z6 engine?
Old Jul 21, 2016 | 10:53 AM
Stock D16Z6 engine?
yes this is my current sol. its not on the road right now. working on her as much as i can first. no idea i never ran the serial number to see whats stock
Click your own VIN link in the first post. The stock engine would be the D16Z6.
Old Jul 21, 2016 | 10:55 AM
Check the head and block codes:
https://honda-tech.com/forums/honda-.../#post48684945
I don't see a timing belt on the pulley, so I wouldn't even crank the engine.
Old Jul 21, 2016 | 10:57 AM
i started her up and drove her for a hour... it actually just started making a quick grinding noise when i start her up. was thinking its the starter but no idea to be honest. ill look up the codes now
Old Jul 21, 2016 | 10:59 AM
Does the water pump pulley turn when you crank the engine? Is the grinding noise coming from the water pump area?
It's clearly time to remove the crank pulley to what surprises are hidden behind the timing belt cover. I assume that a non-stock water pump was installed.
Old Jul 21, 2016 | 11:15 AM
https://i.imgur.com/qb4gOgS.jpg
4314769
https://i.imgur.com/Wyietlo.jpg
P08
I will start her for you now if you want
Old Jul 21, 2016 | 11:36 AM
im uploading a start up vid and the belts running.. im going to just drive it over to my friends garage i guess and start taring it apart. bummed me out tho because i thought i could just bleed the breaks fix the lights and start ripping. guess not tho? im in albany / troy new york i need someone good working on this
Old Jul 21, 2016 | 11:43 AM
also it just started making that crank noise on start up like 3 starts ago
Old Jul 21, 2016 | 12:27 PM
tony_2018's Avatar
Fish Twig
So ghetto....replace all that crap and do some maintenance.
Old Jul 21, 2016 | 12:51 PM
does that vin number say automatic? because this is a 5 speed manual.. anyway yea thanks ill get it all taken care of
Old Jul 21, 2016 | 12:54 PM
Did you click on it?
Old Jul 21, 2016 | 01:48 PM
yea sorry it looks like it said automatic but im not sure thats right or maybe this is a conversion? pretty sure he said stock tranny flywheel motor all that. the guy barely spoke english it was dark and i been up for 2 days i just tossed him the 800 bucks because it was ripping around nice its fast and clutch is strong
Old Jul 21, 2016 | 04:33 PM
tony_2018's Avatar
Fish Twig
So ghetto....
Old Jul 21, 2016 | 04:41 PM
testify's Avatar
On vacation
The starter is sticking open.
Old Jul 21, 2016 | 06:46 PM
lmfao thanks guys. so how much $$ we looking at? just wondering if i should bring this to a place how much it would cost and how hard they will laugh or if i should just have my friend and his dad tare it apart in the yard
Old Jul 21, 2016 | 06:50 PM
To sell it as fast as possible?
Old Jul 21, 2016 | 06:54 PM
you think i should get rid of it?
(i was gonna get this miata instead but i took a gamble on the honda..)
Old Jul 21, 2016 | 07:00 PM
I was joking, but you are likely in for much more than you expected.
Old Jul 21, 2016 | 07:04 PM
i was trying to get new headlights, breaks done, and that headlight switch.. i didnt expect to put over 100$ into the engine.. you think im looking at over 300-400? cuz if so i have to sell it.. anyway thanks getting it looked at tmrw
Old Jul 24, 2016 | 05:51 AM
94EG8's Avatar
Seagull Management
Your pics aren't working and both videos are set to private.
Old Jul 24, 2016 | 11:33 AM
fcm's Avatar
fcm
Old Fart
Same result here. 94
Old Jul 24, 2016 | 11:42 AM
testify's Avatar
On vacation
Yes, you should get rid of it. That thing is a mess.
Old Jul 24, 2016 | 12:10 PM
Possibly by design.
poison
172
Jul 19, 2013 08:08 PM
datsol94
Mar 27, 2011 04:58 PM
ViSiONxBoY
May 1, 2008 01:06 AM
tambara
Jan 3, 2007 10:44 PM
GetawayInMoscow
Jun 27, 2005 07:43 AM
