I need to confirm which timing and water belt to order.
I need to confirm which timing belt and water pump to order.
Okay I am getting a obdI jdm b16 swap for my 93 CX. I searched to find out which timing belt and water pump to get but I got conflicting results.
Should get a timing belt for a 99-00 Civic Si and water pump from a Del Sol VTEC?
Also, which online honda dealer is the best to buy parts from? I got some stuff from majestichonda before and I was pleased.
Modified by GetawayInMoscow at 4:06 PM 6/26/2005
Re: I need to confirm which timing belt and water pump to order. (GetawayInMoscow)
Ive always gone with a t-belt and water pump from a 1995 del sol VTEC. However, most parts are the same from the del sol and a 99-00 si....I just go with the del sol cause hte engine is OBD 1 also.
Re: I need to confirm which timing belt and water pump to order. (civic_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan »</TD></TR><TR><TD CLASS="quote">Ive always gone with a t-belt and water pump from a 1995 del sol VTEC. However, most parts are the same from the del sol and a 99-00 si....I just go with the del sol cause hte engine is OBD 1 also.</TD></TR></TABLE>
Thanks.
Anyone else?
Thanks.
Anyone else?
Re: I need to confirm which timing belt and water pump to order. (BlueIntegraBoy)
Are those part numbers for Honda? What does KEIHIN mean?
Also do I need to get a timing belt tensioner and all that other stuff for when I do my swap or just the belt and pump?
Milan
Milan
bluecrxsi
02-05-2003 07:20 PM
