Quick Steel For Gas Leak
This would be a temporary fix for a week, tops. Yes, there will be people that tell you theirs has held up for years but do you really want to find out for yourself? Your tank needs to be properly repaired or replaced.
Any "quick seal", [external] is a very temp. fix and will not last, a bit better are the internal sealers.
With that said replacing the tank is a far better bet, either way the leaking tank needs to be removed. to properly seal it or replace it. 94
thanks i decided to replace it as i have an extra rex for parts but just needed a temp fix till this weekend
I ran over my jack stand one time put a pretty good size tear not hole in my tank and I used quick steel like 6 months ago working great clean the area and get to the bare metal then apply it should last for ever
kingrukus
Aug 25, 2010 02:32 PM
