Quick Steel For Gas Leak
I got a small gas leak after i got ran into the grass today by a semi and saw some things online about people using quick steel anyone ever tried this?
Re: Quick Steel For Gas Leak
This would be a temporary fix for a week, tops. Yes, there will be people that tell you theirs has held up for years but do you really want to find out for yourself? Your tank needs to be properly repaired or replaced.
Any "quick seal", [external] is a very temp. fix and will not last, a bit better are the internal sealers.
With that said replacing the tank is a far better bet, either way the leaking tank needs to be removed. to properly seal it or replace it. 94 |
thanks i decided to replace it as i have an extra rex for parts but just needed a temp fix till this weekend
Originally Posted by fcm
(Post 50981745)
I ran over my jack stand one time put a pretty good size tear not hole in my tank and I used quick steel like 6 months ago working great clean the area and get to the bare metal then apply it should last for ever
Originally Posted by Blueman5624
(Post 50983149)
just weld it
Originally Posted by acmoc
(Post 50985191)
just weld it
Regards Dave |
Even if welding were a readily available option, you would still need to send it out to have the plastic liner inside done again.
