P30 ECU - leaky capacitors replaced but car runs poorly
Old Jul 10, 2016 | 04:47 AM
cyro's Avatar
Default P30 ECU - leaky capacitors replaced but car runs poorly
Hi!
I have a eg civic with b16a engine and p30 ECU. I got cel with VTEC spool solenoid valve but engine runs smooth just no vtec, I checked the solenoid directly with battery and it clicks meaning its ok. So I check the ECU and saw some leaking capacitors so I thought maybe its the capacitors so I changed all of them. After I changed the capacitors the car starts but has erratic idling on low rpm but sounds ok at higher rpm(didn't check beyond 3000rpm) and exhaust smells bad. I also got cel on.
Yesterday I checked the cel code and it gave me a map sensor code nothing else, but today it gave me a different code, today it was IACV which is code 14.
Any leads on what to check?
Thank you
Old Jul 10, 2016 | 04:22 PM
cyro's Avatar
Default re: P30 ECU - leaky capacitors replaced but car runs poorly
UP, please somebody?
Old Jul 10, 2016 | 04:25 PM
tony_2018's Avatar
Fish Twig
Find another p30, that simple.
Old Jul 11, 2016 | 12:12 AM
cyro's Avatar
Currently looking for one. Thank you
Old Jul 11, 2016 | 11:55 AM
Former User's Avatar
Check your wiring job.
Old Jul 11, 2016 | 10:12 PM
eghatch9295's Avatar
Stancetard Hate Monger
p28 will run it for testing purposes.
Old Jul 18, 2016 | 12:09 AM
cyro's Avatar
Fixed my CEL prob already. Rechecked the ECU behind light and found out that some circuit were corroded by acid from bad capacitors. So I had to solder wire to connect them.
Old Jul 18, 2016 | 06:35 AM
I hope your ECU work lasts.
ryans_crx
Dec 23, 2013 06:27 AM
92DAB16A
Sep 14, 2012 07:14 PM
1sikhatch
Jan 31, 2010 09:06 AM
Brewer
Jul 7, 2004 01:49 PM
splitime
Sep 6, 2002 10:21 AM
