Replaced SRS unit and now getting code 1-1
Old Jun 28, 2016 | 09:03 AM
GRN-BNDT's Avatar
Default Replaced SRS unit and now getting code 1-1
My SRS light came on one day after I turned the ignition on with my cluster unplugged and I recently took it down to Honda after not having any luck resetting the light or pulling codes and they told me the unit went bad, so I went to the junkyard and pulled another unit and put it in. I am able to do the reset procedure not, the light actually turns off and blinks and all that, but after it blinks twice to confirm its been reset, it comes on solid red and doesn't go out. I tried resetting it four times and finally I figured I'd try to pull the codes and I was able to, it have me one long flash and one short flash which I assume is a code 1-1. I looked at the SRS code readout and it says a 1-1 is an "open in the driver's inflator". So, what does that mean? I haven't messed with anything else in the system. The unit I got from the junkyard isn't the same exact unit, it's from a 94 Civic whereas I have a '94 Del Sol, but they both have two airbags and the harness is the same.
Old Jun 28, 2016 | 04:39 PM
fcm's Avatar
fcm
Old Fart
Default Re: Replaced SRS unit and now getting code 1-1
You have a connection problem at the airbag. 94
Old Jun 28, 2016 | 05:05 PM
GRN-BNDT's Avatar
Could that be a bad clock spring? The airbag is plugged in.
Old Jun 28, 2016 | 05:29 PM
fcm's Avatar
fcm
Old Fart
Yes, that is the most common problem, just did a Toyota Corolla with that same exact problem. 94
96civic909
Sep 11, 2012 06:06 PM
ultraforce77
Aug 7, 2004 10:17 AM
acura delsol
Jul 18, 2004 05:54 PM
tomtom211
Jan 6, 2004 01:28 PM
