Sheepy Manifold / Downpipe Question/Help
Old Jun 25, 2016 | 08:32 PM
BlackCivicEX's Avatar
Default Sheepy Manifold / Downpipe Question/Help
Hey guys, i have a ramhorn peakboost manifold. I went to install it today and ran into the problem of the turbo hitting the wastegate. Did some research and recently found these pictures online.
- Question is since i will need a new downpipe. Which style should work with clearance? Would i be needing something like the third picture, Ac compatible?
My apologies in title- peakboost manifold
93 civic eg - b18c1 - any other info you need let me know. Sorry for large pictures
Old Jun 26, 2016 | 09:01 AM
TheShodan's Avatar
Moderator
It's best to get the downpipe the same company as the manifold you bought, or at least one of similar design.
If your manifold and turbo are in the same configuration as the 1st two photos, you need one in 3 " that doors down under the pan.
The third photo you're showing is ridiculous. It has nothing to do with your configuration.
Check Sheepey, check Go-Autoworks.. No eBay company will have a decent downpipe for those manifolds
Old Jun 26, 2016 | 09:27 AM
Default Re: Sheepy Manifold / Downpipe Question/Help
I'm not looking into ebay brands, only as a reference. It'll have to run from the driver side, and loop down through the oil pan, Which wouldn't that be the right type of downpipe style tho?
Old Jun 26, 2016 | 12:20 PM
TheShodan's Avatar
Moderator
no. it would not. The angles on that are very much closer to the block than what your image represents. As I stated, you need to contact the two companies to get the correct downpipe.
Old Jun 26, 2016 | 12:56 PM
Definitely try this week and get a hold of them and see if they would have any available ! Thanks !
lsvsol
May 14, 2006 06:35 AM
Dunc
Jul 21, 2005 03:40 PM
Blindstuff
Oct 5, 2004 06:33 PM
boosted jetta
Jul 7, 2004 08:11 AM
Full-Race Geoff
Jul 17, 2002 05:18 PM
