Help plz 90 f22a1 stumbles under 2k
Hi there I'm new to the forum and need help plz I have a 1990 honda accord It runs great when cold (closed loop) or above 2k rpm things I have done replaced ect sensor under dizzy that talks to ecm replaced upstream 02 sensor tried two different coils both were used out of wreckers thought so may still be coil new plugs cap and wires cleaned egr passages tested egr functions properly and set timing today 15 btdc if I ease into throttle very slowly it runs anything more than a slight throttle it stumbles until it backfires and dies help me please
Just an update took off catalytic converter and still doing it cat I'd going back on now
I'm leaning to a possible clogged cat now. Remove the oxygen sensor after disconnecting the connector and run the car without it and see if it runs better. Yes, it will throw a check engine code but it won't hurt anything. See if it runs better.
Ok sorry I'm taking so long just got off work pull electrical connection from egr after about five mins or so of driving an bogging it down and making it spit and sputter I got the cel to come on car ran way better but it was still there a little but way way better I also took cat off already and made no difference
When you cleaned the passages did you clean the tiny holes in the passages that lead down into the runners? Also I believe there are 5 plugs I believe or maybe 6, but it's more than 4. Been a while since I did them.
There's 6 plugs and yeah I cleaned the holes three were completely plugged
Have you checked fuel pressure? My 92 had a weak fuel pump, the engine would run but it would sputter badly with heavy throttle input. Mine was around 25 psi when running, needs to be 40.
Not yet don't have tool to do it but I can talk to a freind who might thanks for the advice I'll get back asap
So just an update still no fuel pressure check but I did a compression check an cyl 1 is at 150 psi cyl 2 is at 140 cyl 3 is at 95 and 4 is at 130?  appears to be dead or contributing very little when unplugging each cylinder so now my question is could a dead cylinder cause my cat to misfire and stumble under load below 2k rpms but only when engine is warm??
circapunk
Aug 10, 2009 10:13 AM
opg5009
Jun 4, 2007 11:12 AM
