Clutch Won't Engage
I was driving when suddenly the clutch gave out. It won't engage and just goes straight to the floor when pressed. The car is still able to start and can change gears surprisingly. This is a 2015 Accord sport with 18,500 miles. Any thoughts as to what's wrong?
So I have the same problem I am ****** lost changed new clutch new slave cylinder new master cylinder pedal adjusted and when I start the car when it's in neutral the MPH goes to 10mph but if I push the clutch in it goes down to 0mph but here's where I'm like WTF if I put it in gear like 3rd without using the clutch it will go to 35MPH with no crunching sound from the tranny and if I go to 6th gear with using the clutch or not using it, it will still engage with no grinding and accelerate to 60mph keep it mind car does not move at all I'm stationary the whole time won't move
My car is 2005 Honda civic Si EP3 with a k20a2 transmission and k20z1 motor
Well first off call your dealership, they're paying for it as its under warranty. So please report back when there done fixing it. My guess is the clutch pedal system, ie out of fluid, a broken master/slave cylinder, etc. How hard do you drive?
Keiffer, if this problem started after you switched all that stuff, and FYI on a lot of hondas theres really no adjusting to the master cylinder. So the car is stationary and is displaying 10mph, and when you hit the clutch it goes to 0? Either youve got a bad electrical problem or the differential is spinning, ie its engaged in gear, and something is broken (axle maybe?) that isnt letting the car actually move. Need more information from ya. And use some punctuation.
pyrus
11
Mar 31, 2005 03:14 PM
