96 Civic - power door lock problem
Old May 18, 2016 | 06:54 PM
Eormek's Avatar
Default 96 Civic - power door lock problem
Hey guys so I have a 1996 Honda Civic and I know I'm having lock/electrical problems because of the door harness is there anyway to lock the driver side lock without the electrical ??
Old May 18, 2016 | 06:59 PM
FeRReTTi's Avatar
Default re: 96 Civic - power door lock problem
I think you pull the door handle and at the same time manually push the lock into the lock position? Try that and report back!
Old May 19, 2016 | 05:25 AM
Eormek's Avatar
No that doesn't really do anything it doesn't want to move I try locking it from the outside and it doesn't work either
Old May 19, 2016 | 05:27 AM
rob78's Avatar
I have a similar issue with my manual lock 97, I can only lock it from the outside not the inside
Old May 19, 2016 | 08:17 AM
Eormek's Avatar
Mine doesn't even lock from the outside my electrical was working for a while and one day my electric locks didn't want to work so there is no way I can lock the driver door
Old May 19, 2016 | 08:23 AM
chrysler kid's Avatar
You will probably need to take off the door panel to disconnect the actuator. You could also try removing the fuse for the power locks
The door harness connector from the door going to the dash usually gets cracked and results in a bad ground or crunched wires connecting themselves together.
Here is a writeup I did on the power lock system on the 96-98 cars with the door lock module located inside of the drivers side door
https://honda-tech.com/honda-civic-d...ic-hx-3236357/
Old May 19, 2016 | 08:41 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
This is how I lock myself out of the car!
Old May 20, 2016 | 04:46 PM
fcm's Avatar
fcm
Old Fart
Sounds like door lock actuator is seized, and I am pretty sure the actuator and latch are one unit, but I am also sure if that is the case, you should be able to remove the actuator from the latch then reinstall the latch and it will be "manual" door lock.
OR, hit up your local bone yard, [PicknPull] and get a replacement, [over $90 from the dealer, under $30 at Pick] it is more work to remove the latch and then remove the actuator and then reinstall the latch then to just replace with the whole unit, and you would get your full central locking back. 94
Vic3261
Honda Civic (2001 - 2005)
Jun 17, 2020 10:00 PM
eddieE
Nov 5, 2016 01:51 PM
thebriarman
Apr 9, 2012 10:06 AM
MikNomis
11
Sep 16, 2011 02:46 PM
quickluna
Aug 14, 2006 12:25 PM
