y8INTAKE MANIFOLD to y7 head....
What are ALL OF THE INPORTANT THINGS THAT I NEED TO GET TO MAKE THAT SWAP HAPPEN...
1. SENSORS ON Y7fuel injectors ARE DIFERENT FROM Y8 can't swap fuel rails
2.hoses get deleted (wich ones picture please)
3.throttle line braket
4.fuel line from fuel filter to fuel rail... MUST BE LONGER
WHAT ELSE????????
WHAT ELSE????????
if your y8 intake mani is complete, replace injectors from the y8 to the y7, keep y8 fuel rail. now you must use a y7 iacv, unless you wanna change your ecu. now if the y8 IM is from 99-2000 you must block off the little holes on the mating surface of the y8 intake manifold, you also need to block off the air injection port which is on the top of the flange. There is also a vacuum line on the back of the IM that i needed to block off as well. for the throttle body, i used the y7 throttle body and blocked off the IACV on the throttle body using leftover gasket (however i did change ECU's, so i needed to use the y8 IACV. For your case, you might wanna block off the IACV port on the back of the intake manifold) . now i used a bent throttle cable bracket. You need to use the y7 throttle body since they rotate differently. If you wanna keep the stock ecu, you will wanna
Also, the fuel line does not have to be longer. It should be positioned in close to the same spot.
It also only took about 4 seconds on google to find an in depth walk-through with photos on exactly what you are gonna have to do. Go crazy, DO YOUR RESEARCH before asking on the forum.
My y7 to y8 Intake Manifold Swap (pics) - D-series.org
Wow.you are absolutely correct....I just would of wished your INTELIGENT *** wOULd OF sent the EXACT LINK.....THANK YOU FOR WAISTING YOUR UNVALUABLE TIME WRITING....
NEXT TIME ASSUME THAT WHEN A PERSON ASK ABOUT SOMETHING having to do with a problem that came up during a swap we might of allready jumped down YouTube and Google's throat and IT MIGHT MEAN, we are looking for FEEDBACK....
THANKS
THANKS
Not only is the OP missing the required car information...
The condescending feel of every post of OP's has caused this thread to be closed.
No infractions given at this time.
kkim
12
Jul 5, 2005 05:41 PM
trooper0641
18
Aug 29, 2004 03:04 AM
