96 Civic EX/D16Y7 swap - Need OBD2a or OBD2b P2E ECU?
Old May 16, 2016 | 11:21 AM
hondah's Avatar
Default 96 Civic EX/D16Y7 swap - Need OBD2a or OBD2b P2E ECU?
Hi all, I have a 96 Civic EX with a swapped D16y7 engine done by the prev owner. The car does not rev past 6000k rpm. I looked at the ECU and it is a P2P, which I am assuming the owner left in after he did the swap. I am currently looking to buy a P2E ECU, but need guidance on how to find out whether the current engine requires an OBD2a(96-98) or OBD2b(99-00) ECU.
Thanks.
Old May 16, 2016 | 07:51 PM
hondah's Avatar
Default re: 96 Civic EX/D16Y7 swap - Need OBD2a or OBD2b P2E ECU?
Help, just need to know how I can find out whether my engine is obd2a or obd2b. Is there a code etched somewhere on the engine?
Old May 16, 2016 | 09:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have likely not received any responses because there are no easy answers based on the information that you have offered.
Please post a photo of the ECU plugs while they are plugged into the ECU and a photo of the intake manifold that is installed in the car. From there, we can offer up some help.
Old May 16, 2016 | 09:49 PM
hondah's Avatar
Thanks for the response, I will get some photos of the ECU tomorrow. As for the intake manifold, prev owner swapped the y8 manifold for the y7, so the engine is a y7 with a y8 intake manifold.
Old May 17, 2016 | 01:00 AM
eghatch9295's Avatar
Stancetard Hate Monger
should be a. p2e will want a 3 wire iacv.
Old May 17, 2016 | 05:56 AM
StraussBuster's Avatar
The oem ecu is an obd2a.
Old Jun 14, 2019 | 02:06 PM
Bcrichster's Avatar
Default Re: 96 Civic EX/D16Y7 swap - Need OBD2a or OBD2b P2E ECU?
Thanks.
I can confirm P2E ECU is OBD2a.. Just done a Frankenstein Mini-Me (D16Y7 block w/D16Z6 head) swap and used a stock P2P ECU (for VTEC) to replace my P2E.. The oddity of this year's ECU's is that it uses all A, B, C, & D connector plugins
Old Jun 14, 2019 | 07:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
AUTOMATIC 6G Civics use all four ECU plugs... it has nothing to do with whether it is an OBD-2A ('96-98) or OBD-2B ('99-00) chassis.
Old Jun 14, 2019 | 07:51 PM
Bcrichster's Avatar
That's cool to know that it's a 6G thing, Ty-. I went by the actual connector design to label it as OBD2a, since they had 3 rows of connector pins, identical to the several OBD2a ECU images you guys were so excellent to upload . This has been a cool learning experience
Old Jun 14, 2019 | 08:00 PM
muellersfan's Avatar
Just throwing this into the mix. Unlike 96-98 Civics, both manual and auto 99-00 Civics use all 4 ECU connectors.
Old Jun 14, 2019 | 08:09 PM
Bcrichster's Avatar
My only question is.. Does connector B change the VTEC & KS wire install locations? I basically didn't touch connector B for anything.. Stuck with the posted A, C, D
Old Jun 14, 2019 | 08:13 PM
96-98 Civic ECU Connector B only carries auto transmission wires.
Old Jun 14, 2019 | 08:16 PM
Bcrichster's Avatar
That's awesome, thanks again
Zeroamaze
May 23, 2019 12:59 PM
Ridinlow_civic
Oct 31, 2017 04:32 PM
DSM95AWD
13
Mar 12, 2014 07:16 AM
honda2nr98
Sep 6, 2006 08:20 AM
