Questions about swapping a replacement Y8 engine and P2P ecu into a 96 Civic EX
Old 07-13-2009, 10:58 PM
New User
DSM95AWD's Avatar
Default Questions about swapping a replacement Y8 engine and P2P ecu into a 96 Civic EX
First off this is my first post, and this will be my first time working on a honda. I am an avid DSM guy, but my buddies DD took a terd. He was desperate and impatient and just bough on a whim a D16Y8 Engine for 400 dollars and a P2P A01 ecu for 40. His car is a 96 civic EX. I plan on helping him do this swap and am wondering what all is necessary. Thanx for any help.
DSM95AWD is offline
Old 07-13-2009, 11:18 PM
Ruben19's Avatar
Default Re: Y8 P2P ecu 96 EX
well, since you have the motor down. change your timing belt & water pump as well. everything else is a direct swap
Ruben19 is offline
Old 07-14-2009, 03:07 AM
New User
DSM95AWD's Avatar
I wont have a problem with the ecu? Im sure going from non v-tec to v-tec something will have to be different with ecu/wiring?
DSM95AWD is offline
Old 07-14-2009, 07:41 AM
JShull's Avatar
If he has an EX it already had a Y8 in it. You should be able to just swap the block in and be good to go.
JShull is offline
Old 07-14-2009, 09:37 AM
New User
gamerguyTHXtss's Avatar
Yes I already have a 96 Ex. As you said it should already have a D16 Vtec in it. Thing is when I bought it, it didn't. Something is ****ed up here but I don't know what.
gamerguyTHXtss is offline
Old 07-14-2009, 07:43 PM
JShull's Avatar
What engine did it come with?
Check where the solenoid would be. Do you have any extra plugs chilling there. (Check for the VTEC plug, you may not have to wire in the stuff for vtec if its there.
JShull is offline
Old 07-15-2009, 07:49 AM
New User
DSM95AWD's Avatar
After checking it out, my old engine was a B16y8, wiered thing is it says no where on the engine or car its a vtec, and my insurance card says its a civic AuX.
DSM95AWD is offline
Old 07-16-2009, 02:53 AM
boost SOHC's Avatar
something sounds funny there
boost SOHC is offline
Old 07-18-2009, 06:51 AM
JShull's Avatar
The valve covers on the Y8s never had "vtec" on them they just said "Honda" and were the same on the Y7. My EX didn't have anything that said vtec either but it was pretty easy to tell I had a y8 with the stamp on the engine, solenoid, and the intake manifold.
Since it has a D16y8 in it already you won't have to do any wiring and there is a very good chance you won't even have to change the ecu. Swap can be done in 4 hours or so. Good luck!
JShull is offline
Old 08-28-2009, 03:10 PM
HondaSPEC99's Avatar
Hey I have a 99 civic Ex MT and its got the P2P Vtec ECU. I put a Skunk2 Intake manifold plus a 68mm TB on the stock D16y8 motor its got (4-2-1 DCS header, Full Skunk2 Exhuast sys, AEM short ram intake) and thats about it. Will the intake and TB hurt anything in my motor or make my car through codes?????
What size injectors would be pref for my civic D16y8 with the S2 manny and 68mm TB?
Is my ECU fine with all that (P2P Vtec ECU)?
HondaSPEC99 is offline
Old 03-12-2014, 05:10 AM
PistolCtyVa's Avatar
I kno this is old but what was stamped on the intake,solenoid to show you its a y8
PistolCtyVa is offline
Old 03-12-2014, 05:46 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Don't bump old threads, start a new one instead.
doctorake is offline
Old 03-12-2014, 07:14 AM
Former User's Avatar
Old thread closed.
Former User is offline
Old 03-12-2014, 07:16 AM
Post these questions in your current thread.
hondah
12
06-14-2019 08:16 PM
dumpstering
07-03-2012 09:44 AM
SouthernComfort
14
04-26-2007 01:24 AM
Quick Reply: Questions about swapping a replacement Y8 engine and P2P ecu into a 96 Civic EX
