2000 Civic EX - door window problems (solved)
Old May 11, 2016 | 05:20 AM
PR8urVtec's Avatar
Default 2000 Civic EX - door window problems (solved)
I'm having a problem with my passenger window. They are power windows and when I roll the window up before it gets to the top of the window jam the glass starts to jump and makes a popping noise. At that time the glass seems to feel like it has play in the up and down direction. I have to push the glass up in to the top of the window then hit the window switch and the glass will moved up to the correct location and stay there.
Does this sound like a regulator problem or something to do with the tracks? I found this thread and a it's similar to my problem but nobody ever said what parts they replaced to fix the problem. I will post a video in a few. I'm hoping it's just a regulator problem and maybe lubing the tracks?
Old May 11, 2016 | 08:34 AM
Former User's Avatar
Default re: 2000 Civic EX - door window problems (solved)
Remove door panel and inspect window regulator for a loose rivet at the center joint. Also inspect the rubber window glass side channels for damage.
When you have fixed the problem, be sure to align the glass as detailed in the 96-00 Civic service Helm's manual.
Old May 11, 2016 | 10:04 AM
PR8urVtec's Avatar
I did remove the door card to inspect things but it is hard to really see inside when the glass is in the up position. I didn't inspect the center rivet though. I did notice that the glass does move slow on the way up and it wasn't lining up perfect before this problem started. I think the glass would drop a hair over time as well b/c I could hear air coming in and I would have to hit the window switch to close it all the sway.
Old May 11, 2016 | 10:08 AM
Sedan or coupe?
Old May 11, 2016 | 10:35 AM
PR8urVtec's Avatar
Coupe
Old May 11, 2016 | 10:41 AM
Remove panel and plastic cover. Roll glass to various positions to inspect center rivet joint and rubber glass run channel.
Remove glass, regulator, and glass run channel, if necessary.
Old May 11, 2016 | 10:53 AM
PR8urVtec's Avatar
So if the rivet is bad or loose I should replace the regulator? I will check it out when I get home from work this evening. Thanks for that diagram.
HarunaEj8's Avatar
i have had a similar problem with actually every 96-00 civic ive ever had seems there is a trend with window problems on the ej model civics mine the front of the window would generally fall to the bottom of the track and id have to take of the door panel and reset and re screw the track down perhaps the threads on the tracks on this model of civic doesnt quite have the same dexterity as later or newer model civics? and it only happens to me with power windows
Old May 11, 2016 | 10:54 AM
Yep. The joint should have little or no freeplay.
Old May 11, 2016 | 12:39 PM
PR8urVtec's Avatar
Ok cool. I will check it out. Thanks for the assistance!
Old May 16, 2016 | 06:01 AM
PR8urVtec's Avatar
Just wanted to update the thread.
Problem was the window regulator. The rivet was bad when I removed it. Swapped in new regulator and problem is resolved. The job took about 30 minutes. Thanks for the help.
Old May 16, 2016 | 07:47 AM
tony_2018's Avatar
Fish Twig
Default Re: 2000 Civic EX - door window problems (solved)
PRAISE THE LAWD!!!
dingobat
Oct 9, 2008 09:56 AM
4Dinsaneb16
Mar 20, 2007 01:30 PM
OriginalFive
Honda S2000
May 3, 2006 10:11 AM
Yellb16crxsi
Mar 5, 2003 04:39 PM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
