93 Civic/B18A1 swap - Idle problems
Old Apr 21, 2016 | 07:11 PM
chicklet's Avatar
Icon5 93 Civic/B18A1 swap - Idle problems
So, i have been having this problem with my car. It'll idle poorly when it firsts turns over then after a little bit of time, the check engine light comes on it stops that. So it falls into a fail safe mode for it. But I'm trying to figure if its the IACV or the mass airflow sensor. Its a B18A1 engine and I have taken apart the intake all the way up to the throttle body and cant find the MAF (unless I'm just missing it). But please help
Old Apr 21, 2016 | 08:27 PM
Former User's Avatar
Default re: 93 Civic/B18A1 swap - Idle problems
Car? Engine? CEL codes? See forum Rules sticky.
Old Apr 21, 2016 | 08:44 PM
chicklet's Avatar
93 EG6 si B18A1 swap
Old Apr 21, 2016 | 09:40 PM
CEL codes?
Also, what ECU?
Old Apr 21, 2016 | 09:42 PM
chicklet's Avatar
Also, what ECU?
not 100% sure
Old Apr 21, 2016 | 09:44 PM
Remove passenger kick panel and post pics of ECU label.
Have you checked for CEL codes? Does the CEL remain on while driving?
Old Apr 25, 2016 | 12:36 PM
chicklet's Avatar
Default Re: 93 Civic/B18A1 swap - Idle problems
So i has able to pull a 7 and a 16, but now that it wont start im trying again and im getting a steady cel. I don't know how to troubleshoot that one.
Old Apr 25, 2016 | 12:44 PM
What ECU?
If you reset the ECU, do both codes return?
If so, resolder the main relay, and check whether fuses 24 and/or 31 is blown.
Also check whether the TPS is plugged in.
Old Apr 25, 2016 | 12:48 PM
chicklet's Avatar
What ECU?
How could i be able to tell what kind of ecu it is?
Old Apr 25, 2016 | 12:49 PM
chicklet's Avatar
And i checked the tps and it looked fine.
Old Apr 25, 2016 | 12:53 PM
Old Apr 25, 2016 | 01:00 PM
chicklet's Avatar
Im assuming its a p28
Old Apr 25, 2016 | 01:02 PM
As a stock P28 is not a fit for a B18A engine, the P28 should be chipped with a B18A basemap. You need to open up the ECU and post pictures to verify.
Old Apr 25, 2016 | 05:55 PM
chicklet's Avatar
I can not get the ecu open unfortunately. But it was running last week. I just woke up one morning and tried cranking it and it didn't work
Old Apr 25, 2016 | 05:56 PM
chicklet's Avatar
One of the middle screws is not coming out is why i cant get it out
Old Apr 25, 2016 | 07:05 PM
Remove the 7.5A hood BackUp fuse for 5 minutes. Then resinstall. Turn key to ON(II). If the CEL stays on steady, pull the codes again and post them.
Also check whether fuses 24 and/or 31 is blown.
Post a picture of the TPS.
Old Apr 26, 2016 | 10:02 PM
chicklet's Avatar
I will do that when i get the car back. Its currently at the shop to get the starting problem fixed. They told me it might be the distributor. So hopefully its just one part )
Cody C
12
Dec 22, 2018 10:53 AM
alextech
12
Nov 24, 2018 06:29 AM
LtFerris
Mar 2, 2014 07:07 PM
XECCHISONX
10
Nov 17, 2011 10:13 AM
nkcalvert09
Apr 25, 2011 06:48 PM
