d15b forged build
Old Apr 21, 2016 | 09:27 AM
lowlownsloslo's Avatar
Default d15b forged build
Hey everyone! I have a turbo d15b non vtec with built head but stock block... My questions were was what forged pistons, rods, amd sleves should I use, because im having a hard time finding ANYTHING on the d15b since they are not used as turbo builds often. I heard the crankshafts in the motor should be bullet proof. Is that correct? Im running 18psi at the moment and im awaire i will blow the block soon.. P.S i dont want to hear about how i should swap to a b.. That is not really in the qestion right now.. Thank yall
Old Apr 21, 2016 | 01:43 PM
Default Re: d15b forged build
And would the d16z6 rods work in the d15b?? On wiki it says there both 137mm but I'm not totally sure i trust it.
Old Apr 23, 2016 | 01:17 PM
2kdrift's Avatar
Crank is fine, Its been ahwile since i played with D series pretty sure it had different rods, just checked eagle rod listing and did not specify it will work with d15, maybe check with go autoworks? he knows D series pretty well.
stock sleeves Im not sure of but im sure there less then b series so maybe good till about 250.
whats your power goal
Old Apr 23, 2016 | 01:21 PM
I want to push around 450-500. Right now I'm over 250hp on stock sleves but I'm trying to not push the motor too hard right now
Old Apr 23, 2016 | 03:21 PM
2kdrift's Avatar
so hard not to blurt out B SERIES YO.....you will definetly need aftermarket sleeves, golden eagle or benson come to mind
Old Apr 23, 2016 | 03:22 PM
Yeah man. I would absulutly love a b series and will get one as soon as I can �� Thanks for the help!
Old Apr 23, 2016 | 03:41 PM
2kdrift's Avatar
You can find a complete swap on H motors for about the same as sleeving and rebuilding the D series
Ohh by the way u might try driving a 300-400 hp honda......recently got tuned on 400hp its by far the fastest car ive ever owned or driven. 4th/5th at this power level scares me I wouldn't want any more, at least on the top end I do like the mid range power tho
Old Apr 23, 2016 | 04:22 PM
Right now the car is pushing 350 HP, I'm just trying to get it past the 450ish mark
Old Apr 23, 2016 | 04:54 PM
2kdrift's Avatar
350hp? stock rods?
Old Apr 23, 2016 | 05:25 PM
It was on a built block but finaly blew after running 26psi for months.. It's on a stock block completley and a ticking time bomb..
Old Apr 23, 2016 | 05:31 PM
2kdrift's Avatar
sounds that way I know d15/d16 rods dont like anything over 250, I actually bent a rod on a d15z at about 200hp. perhaps d15b rods are larger
Old Apr 23, 2016 | 05:33 PM
I heard the d15b rods were like tooth pick.. We will see lol
Old Apr 24, 2016 | 10:42 AM
96ekb20's Avatar
if you went to a d16 block and crank you could use b18b rods
Old Apr 24, 2016 | 11:23 AM
sr20paisa's Avatar
there a some meaty rods for d15's for around 200 on ebay
Old Apr 25, 2016 | 01:03 PM
Txdragon's Avatar
Of all the D15 build stuff I have searched for, there is a lot of info. BUT, a lot of it involves started projects that never finished. Few built, even fewer stock. Most of the newest info was from around 2014 but those projects never saw through. Now that being said...
Failed D15 builds that I managed to find seem to have destructed due to breaking bearing cap bolts.
jdmpoweredsol419
Jun 2, 2009 05:34 AM
Everyones Hero
Mar 22, 2006 06:37 AM
fxrob
Jan 29, 2005 08:14 AM
SlowSOHC-T
Jan 21, 2005 09:46 AM
Bakeoff
Feb 1, 2004 07:11 PM
