Help with 90 CRX hazards and turn signals.
I recently purchased a 90 CRX but my hazards and turn signals do not work. They don't even light up on the dash. I've checked all my fuses and they all seem fine. Any idea why they aren't working?
Any help is appreciated guys.
Ditto the above^^^, both hazard and signal lights power goes through the hazard switch.
If it is plugged in, you will need to test the switch, if good, the problem is most likely the hazard/signal light relay. 94
Should be upper left of under dash fuse box, 3 pin relay, one of the pins, [top] in the socket should be 12V+ when signal or hazards are turned on, one will be a ground at all times, [bottom] the 3rd one, [left side] is the output, supplying power to it will turn on the signal lights, [left or right] is signal light switch is on, and hazard switch off, both sides will turn on if hazard switch is on. 94
slowslow
Nov 5, 2010 11:57 AM
