Buggin!!
Old Sep 30, 2013 | 11:25 PM
Maine323's Avatar
Default Buggin!!
I have a 94 Honda Accord EX and for some reason my turning lights don't blink anymore. I changed the switch and the relay still nothing. Can someone tell me what seems to be the problem?
Thank you!!
Old Oct 1, 2013 | 04:15 PM
motoxxxman's Avatar
Default Re: Buggin!!
do they come on solid? or do they not come on at all?
(the actual bulbs, not the dash)
Old Oct 1, 2013 | 05:41 PM
KidRuthless's Avatar
Agreed if the bulb is not on at all you may have a blown bulb
Old Oct 7, 2013 | 05:59 AM
Maine323's Avatar
The bulbs work fine. When i push in the hazard switch a little the signals work. I changed the hazard switch and still not working. Bought a new hazard switch and still not working but when i put in the old hazard switch and push it in a little, they work. I hear you can bypass the hazard relay but i don't know what to do. Does anyone know how?
Old Oct 7, 2013 | 06:52 AM
fcm's Avatar
fcm
Old Fart
If the hazard lights work, [blink when hazard switch pressed] the problem is either the hazard light switch or power for the signal lights, everything after the hazard switch, [including flasher relay] is common for hazard lights and signal lights.
Pull the hazard switch and test for power, [ign. switch on] on the yellow/white lead, [signal light power].
If no power, check fuse 12- 7.5A, [hot when ign switch. is on] in AUX fuse holder in left kick panel.
If fuse is good, [power at both test tips] check continuity of yellow/white lead between fuse and hazard switch. 94
Old Oct 18, 2013 | 12:34 AM
Maine323's Avatar
It seems to only have power when i push in the hazard switch a little. I put something in the hazard switch with it pushed in a little and my signals work like they should. They just don't work without it being pushed in. If i can't find a way to fix this, without having to trace the wire and all that, i'll just ride with it the way it is. Its really buggin me though.
snake_eyes
36
Feb 26, 2011 08:20 PM
redheadsSI
Jan 29, 2010 06:08 AM
4DRmafia
Nov 9, 2006 09:48 PM
PokeyD16Z
Jan 20, 2005 03:18 PM
BlazinITR
Jan 24, 2003 01:05 PM
