Help with 90 CRX hazards and turn signals.
I recently purchased a 90 CRX but my hazards and turn signals do not work. They don't even light up on the dash. I've checked all my fuses and they all seem fine. Any idea why they aren't working?
Any help is appreciated guys. |
Re: Help with 90 CRX hazards and turn signals.
Is the hazard switch connected?
Ditto the above^^^, both hazard and signal lights power goes through the hazard switch.
If it is plugged in, you will need to test the switch, if good, the problem is most likely the hazard/signal light relay. 94 |
Yeah it is connected I took apart my dash to check and it is. How can I test my switch?
Ok I replaced my switch and still nothing where is the relay located so I can try to change it.
Should be upper left of under dash fuse box, 3 pin relay, one of the pins, [top] in the socket should be 12V+ when signal or hazards are turned on, one will be a ground at all times, [bottom] the 3rd one, [left side] is the output, supplying power to it will turn on the signal lights, [left or right] is signal light switch is on, and hazard switch off, both sides will turn on if hazard switch is on. 94
Thank you so much man. Switching the relay fixed my problem. Saved me money by not going to a electrical shop so thank you so much again.
