Suspension & Brakes Theory, alignment, spring rates....
00 integra suspension set up for heavy audio equipment?
Old Apr 8, 2016 | 08:22 PM
89brokendownEF's Avatar
Default 00 integra suspension set up for heavy audio equipment?
hello. i have the 2000ls integra i got the pioneer primer 3000 watt speakers which are going to be installed and two amps to run all interior and rear pioneers 12's
with all this extra weight am i going to have to do anything to suspension?
Old Apr 8, 2016 | 08:33 PM
Default Re: 00 integra suspension set up for heavy audio equipment?
what shocks and spring set up recommended for the 00 integra i want to do a 1.5 - 1.75 in drop give or take maybe more in front than rear due to weight of sount system
Old Apr 8, 2016 | 08:34 PM
i want to go low budget. i figure around 500-600 for all components. what should i get?
Old Apr 8, 2016 | 08:54 PM
Stagg SHS 2 Rear Shocks Struts Acura Integra 94 95 96 97 98 99 00 01 | eBay
Stagg SHS 2 Front Shocks Acura Integra 94 95 96 97 98 99 00 01 | eBay
here are two links. do you think these will be good enough for my suspension set up? or junk ?
Old Apr 8, 2016 | 08:55 PM
should i just buy some oem spec struts and get coilovers?
Old Apr 9, 2016 | 04:44 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Buy tein street basis or street advance coilovers from thmotorsports. Raise the back up higher to account for more weight.
Old Apr 9, 2016 | 04:45 PM
B serious's Avatar
I am aware that this is likely a troll post, BTW.
Old Apr 9, 2016 | 07:23 PM
ok i looked at the tein u suggested i like them what would i do for the top buy new top hat? or use what i have stock? is this all needed to lower 1.5 - 1.75 inches. i do not want my wheels all cocked in or out either i just want them like oem
Old Apr 9, 2016 | 07:30 PM
what do u mean troll post?
Old Apr 9, 2016 | 08:26 PM
98civdx's Avatar
Master Detailer
because that isn't really enough weight to affect anything.
Old Apr 10, 2016 | 04:27 PM
it is going to total around 200-300 pounds of extra weight in rear. my car sags in the back as of now with the audio components in.
Old Apr 10, 2016 | 07:23 PM
B serious's Avatar
200-300 LB is significant.
You'd re-use your OEM top hats with the Teins, OP. The damper adjustments on the street advance may come in handy to you. I believe they're only like $75 more than the SB's.
Old May 29, 2019 | 07:57 PM
I know this is an old thread but I never got the coilovers, I replaced front shocks with OEM replacements. I plan to do the same with rear, but is there a spacer or something I can put on top of the shock to raise the rear a bit to prevent the sagging from my woofers. Thanks
Old May 29, 2019 | 10:33 PM
Tyson's Avatar
https://www.google.com/search?q=spring+spacers
dakorm
Suspension & Brakes
Feb 1, 2010 01:57 PM
Fibercation
Aug 21, 2008 05:04 PM
RudeLude83
Oct 3, 2007 12:21 PM
mRvYbEs
Mar 29, 2004 01:06 AM
