Lighting HID/Xenon kits, Retrofits and Associated Topics
H4 Single Beam Kit only works on High Beam
Old Apr 3, 2016 | 05:21 PM
Bleakened's Avatar
Default H4 Single Beam Kit only works on High Beam
Hello, H-T! I have installed an H4 Single Beam on my 1998 Honda Civic DX hatch and no matter what configuration I plug the positive and negative wires into my harness, it will either not work at all or only on high beam.
The kits harness isn't wrong as far as I can tell as it's set up to be fool-proof with connectors that won't allow an incorrect setup.
So is my setup I bought defective? It's low beam only and will turn on and work normally but only when hooked up to my highs.
Any ideas? Everywhere I search is someone having problems with the bi-xenon that have both low and high beam but has a 3 wire setup and mines a 2 wire setup.
Old Apr 4, 2016 | 03:12 PM
LowTEC SaiMike's Avatar
Default Re: H4 Single Beam Kit only works on High Beam
It should be fairly simple for this setup. On the car side . Double check to see which which prong is power , ground and High beam .
Match up the power and ground and leave the high beam prong alone . Do you have pictures of the plug for the bulb and one on the car side ?
Old Apr 12, 2016 | 04:24 AM
tony_2018's Avatar
Fish Twig
You have the wrong kit but if you want to continue using it than you'll need to re-pin the the 3-prong connector.
Rodney Williams
Lighting
Oct 30, 2014 08:45 PM
ef yu
Lighting
Mar 15, 2010 09:20 PM
chairwitharmrests
Lighting
Sep 3, 2008 12:48 PM
rsdriver17
Lighting
Mar 5, 2008 11:03 AM
dcaccord
Feb 25, 2002 12:18 PM
