1995 civic issue with rpm gauge
Old Mar 29, 2016 | 08:40 AM
topshotta's Avatar
Default 1995 civic issue with rpm gauge
1995 civic ex
Motor 00 lsv --- never had an issue with the rpm gauge before now.
The car wasn't started up all winter. Had it jumped now the rpm gauge is going crazy. Going pass the 9,000 mark an not comming back.
Checked my distributor an my ground wires , they all look good
Any suggestion. Please see video for more details
Old Mar 29, 2016 | 08:48 AM
DA9_LEO's Avatar
Default Re: 1995 civic issue with rpm gauge
Check Dizzy, Blue wire on the plug is for RPM input, if no issues there might need to pull cluster out and check wiring in the back of cluster
Old Mar 29, 2016 | 08:57 AM
topshotta's Avatar
Did all that same thing
Old Mar 29, 2016 | 09:16 AM
Former User's Avatar
Might also be a bad igniter unit.
Old Mar 29, 2016 | 09:59 AM
topshotta's Avatar
so ur saying my distributor is on its way out?
Old Mar 29, 2016 | 02:22 PM
mk378's Avatar
Does it read zero with the key off? If not, the gauge pointer is probably mechanically stuck.
Old Mar 29, 2016 | 02:55 PM
09chaplak's Avatar
Loves Tossing Salad
Does this help? https://honda-tech.com/honda-civic-d...issue-3212540/
Old Mar 30, 2016 | 08:54 AM
topshotta's Avatar
no it does not read zero when the key is off.
Originally Posted by 09chaplak
this looks like the same issue i'm having. I have a video of it but i can;t upload it.
https://www.youtube.com/watch?v=WMXaBKp6dK0
please see attached video
Old Mar 30, 2016 | 10:36 AM
The video should have been included in your first post. It points to a bad tach. Replace the tach.
Old Mar 30, 2016 | 01:39 PM
topshotta's Avatar
Couldn't get the video to upload on here, so i decided to post it to youtube then post it here. Thanks for the advise.
Old Mar 31, 2016 | 07:55 AM
09chaplak's Avatar
Loves Tossing Salad
Do the EJ6's have CFK's? I don't recall but check to be sure all wire harnesses near any belts aren't chewed up and placed correctly. Bad tach is most likely the issue here.
Finally, one of my threads did some good to someone else =]
89SiZero
Jul 22, 2014 09:15 AM
bOOsted_D16
Mar 19, 2008 09:52 AM
b16a1eg6
Oct 5, 2007 03:16 PM
myronwong
Nov 14, 2005 09:13 PM
anekin007
Sep 23, 2004 08:46 AM
