2000 Acura EL (Civic EX) - Very low Idle
Hi, bought an EL (basically a Civic EX with an Si engine and leather seats) fully loaded for my ma, fantastic car, except it idles at around 100-300 (almost stalling) when warm.
The guy I bought it from said it sat for 1 year without being driven (his wife got a new car). So he had to boost the car to start it.
The car starts up after cranking a bit, the battery terminals are pretty much corroded with blue stuff.
The low idle sounds like an IAC issue. Should I clean it out?
Also, would replacing the battery help with low idle?
Thanks
Thanks
Does the car have any maintenance record?
If not, I would start a good ignition tune up.
Plugs, cap, rotor, ignition wires.
Then
Fuel filter, injectors cleaner, fresh new fuel with cleaning detergent ( shellv or bp)
Clean throttle body
If high mileage:
Send out injectors to get service.
Then
Clean throttle body
If high mileage:
SOHCgirl
12
Jul 4, 2015 11:01 PM
motegicivic
May 6, 2012 12:02 AM
