removing turbo oil lines from d16
hey guys
new here and a total newbie to engine modifications (besides the basic ****). my car previously had a turbo kit on it, i removed most of it but the turbo oil lines. i know what do to but was wondering about the sensor. after i take out the turbo line with its sensor on it where can i get an oem replcement one to put back on the car? or can i reuse the one on the turbo line?
thanks a lot, trying to get my car back on the road asap so please any help would be great!
hey guys
If you want a new sensor get it from the dealer or find a used one on ebay
okay cool thanks a lot guys,
just to be on the safe side i might just take it to the shop. so the oil sensor is T'ed with the oil line if i got that correctly.
appreciate the quick response!
you are removing the turbo system correct? where does the oil line goto? (multiple ways to to do this and im not sure what your working with...pics?)
anyway If I understood your original post, you are removing the turbo, and the turbo feed line currently goes to the back of the block?
If this is the case remove the oil line completely, remove the T fitting, remove the sensor from the t fitting, toss the oil line and t fitting (or sell it) then reinstall the sensor back into the block
then get a cap for the drain (the one that goes to the oil pan) and cap off whatever fitting is on there so your not leaking oil all over the place
again pics would help as Im kinda just trying to imagine what you are dealing with
