Tungsten question
Old Mar 14, 2016 | 06:12 AM
efHondefender's Avatar
Default Tungsten question
Can somebody point me in the right direction? I'm trying to weld some 0.125" 6061 t6 together and my tungsten keeps splintering at the amps that I'm at. I'm using 1/8" and still having problems. I've tried the balance as low as 50 and as high as 80 and freq. between 60 and 100. The tungsten I'm using is either ceriated or lanthanated. It's hard to tell because the band is almost worn away.
I was gonna head down to the welding store and pick up some pure tungsten 3/32 and 1/8 to see if that helps. BTW... Using an HTP 221 inverter.
Old Mar 14, 2016 | 06:39 AM
LightningTeg's Avatar
Community Builder
Default Re: Tungsten question
2% Lanthanated, 3/32 should do it?
Old Mar 14, 2016 | 08:11 AM
seelback's Avatar
+1
Old Mar 14, 2016 | 09:16 AM
that's what I thought too, but it's not taking the heat. Maybe the stuff I have is ceriated. Not sure how much that would matter. I picked up some 3/32 and 1/8" pure a little earlier. I'll give that a try.
Old Mar 14, 2016 | 10:14 AM
Community Builder
The 2% lanthanated has a blue end.
Good video on Tungstens
Old Mar 14, 2016 | 01:20 PM
turbohatch96y7's Avatar
I use red tungsten for everything 3/32
Old Mar 14, 2016 | 03:03 PM
aluthman's Avatar
I've had 3/32" 2% lanthanated split on me at 100-120 amps on AC. If you have an inverter machine, just use 2% thoriated. It will ball up a bit, but seems to handle the heat better than lanthanated. AC welding puts a lot more heat into the electrode than DC welding at the same amps. Your balance setting also plays into this, as the more cleaning action you get, the more punishment the tungsten takes.
Old Mar 15, 2016 | 06:18 AM
I think mine was 1.5% lanthanated which is gold tip. It was either gold or orange. Might have been ceriated.
Old Mar 15, 2016 | 09:09 AM
Community Builder
Thats probably why. Surprisingly big difference between 1.5% and 2%
Old Mar 16, 2016 | 05:19 PM
kr3w108's Avatar
I always use 2% thoriated for DC and Ceriated for my AC welding....
tepid1
Paint and Body
Apr 9, 2010 02:15 AM
TurboInteg95
Welding / Fabrication
12
Mar 24, 2006 09:02 AM
1 2 NV
Nov 14, 2004 07:11 AM
CaptainGSR
15
Jun 19, 2004 08:00 PM
