Needing advice on my b18c1 build
Old Mar 13, 2016 | 06:13 PM
RP-0922's Avatar
Default Needing advice on my b18c1 build
Hey guys ive been lurking and doing alot of research for awhile now. But i cant seem to find all the answers im looking for by searching.
So my questions; Im looking to make 600hp on e85 boosted of course.
I plan to use the stock crank and have it micro-polished.
How low of compression do I need to go ex. what piston/rod combo
Does anyone have and good recommendations for the turbo?
Also will a factory gsr oil pump be sufficient? Should I keep the Oil squirters?
What head gasket should I run?
Also what is a reputable website for ordering these parts?
I appreciate any help that you guys give.
Old Mar 15, 2016 | 10:58 AM
h22silvia's Avatar
Default Re: Needing advice on my b18c1 build
I'm going through the same thing and i am considering taking my long block to golden eagle and they gave me some advice and quotation.
Old Mar 15, 2016 | 11:14 AM
LightningTeg's Avatar
Community Builder
FAQ at the top of the sub forum should answer a lot of these questions.
Old Mar 17, 2016 | 11:36 PM
extremeracer's Avatar
There are a lot of threads on here that you can go look at, so members will be reluctant to answer questions posted that are covered by FAQ's
Here's some answers for you:
> Sleeve the block - ERL/Darton/Golden Eagle
> Forged Pistons Most run 10:1 compression ratios with E85 (CP's 9.7:1/10:1 piston is popular just get the upgraded wrist pins). Don't go any lower than 9:1
> Eagle H-beam/Manley H or H Tuff/K1 rods will suit your power goal
> ARP headstuds
> Stock oil pump is fine
> Keep the squirters
> OEM Honda gasket - always
> Stock cams are fine, or you can upgrade to ITR/CTR/Skunk Pro 1/GSC T1
Turbo choice depends on your intended usage, budget and to some degree brand preference.
Garrett GT3582R/GTX3576R/GTX3582/GTW3476/GTW3684R
Borg Warner S362 SXE
Precision 6062 Gen 2
Xona 7164/7864
Those will all get the job done, the Borg Warner S362 SX-E is a nice unit which offers good value and solid durability.
Check out the Marketplace section of the forum for Vendors that support Honda-Tech
Old Mar 18, 2016 | 04:53 AM
Stopsign32v's Avatar
Loved
Originally Posted by extremeracer
> Keep the squirters
From everything I've read, don't do this.
Old Mar 18, 2016 | 06:13 AM
Community Builder
Forged pistons dont need them and the added benefit is more oil pressure
Old Mar 18, 2016 | 06:48 AM
This is true ;-)
Old Mar 18, 2016 | 06:51 AM
Geis's Avatar
What's the car's purpose
Old Mar 18, 2016 | 06:47 PM
RP-0922's Avatar
Thanks for the advice so far. Any reason you would choose CP pistons over wiseco or anyother big company? The purpose for the engine im pretty sure im going to buy a hatch roller once this is finished and use it as strictly a drag car
Old Mar 18, 2016 | 06:50 PM
kr3w108's Avatar
honestly staying around 10:0 to 10:5 would be good for a street car. If you looking for more performance then 11:0 to 11:5 is what most people run in the drag setups.
Ive always used Wiseco on my builds.
Old Mar 19, 2016 | 06:34 AM
Community Builder
The CPs in my car have been in the bottom end for almost 10 years.
DC2story
Apr 20, 2016 05:15 PM
94_Integra GSR
Mar 24, 2012 10:04 AM
SR20?
Nov 7, 2011 06:37 PM
jorge59la
Apr 23, 2008 05:12 PM
ek9tl
May 11, 2007 02:50 PM
