Building a B18C1 - Suggestions?
Old Nov 7, 2011 | 07:09 AM
SR20?'s Avatar
Default Building a B18C1 - Suggestions?
I'm going to be building a B18C1 for my 97 EK. I'm only looking to make a reliable 300-350 whp with this setup. I'm pretty new to the Honda game and I was wanting some opinions and suggestions on things you guys might change or things you might add. Here is the setup:
Wiseco 8.6:1 pistons
Eagle rods
Clevite race bearings - main, rod, thrust
ARP head studs
ARP main studs
OEM Type R oil pump
Supertech valve springs and retainers
Gates kevlar timing belt
I'm not sure where to find a good engine gasket kit with a cometic headgasket so maybe you guys could point me in the right direction. Also, I've done some reading about the oil pump gear and supposedly they aren't very strong. Would you guys upgrade the oil pump gear? And I'm kinda curious about what power level I should sleeve the block at. I'll appreciate any help I can get. Thanks
Old Nov 7, 2011 | 07:22 AM
EasternBandit's Avatar
Default Re: Building a B18C1 - Suggestions?
List looks pretty good. I probably wouldn't go with that low of compression but that's up to you.
I'd just use a gasket set from honda with OEM headgasket. The oil pump should be fine. 300-350whp is fine on stock sleeves. If you plan to do more than ~450whp later and you have the funds it'd be better to sleeve the block now and not worry about it. Just remember, boost is addictive.
Old Nov 7, 2011 | 07:52 AM
SR20?'s Avatar
You sure the oem headgasket will be ok for 20ish psi?
Old Nov 7, 2011 | 08:01 AM
TheShodan's Avatar
Moderator
Yep. And that compression is a bit low for that. Unlike other platforms, higher static compression is more usable than you think
Old Nov 7, 2011 | 02:24 PM
Slim1320racing's Avatar
U should go for a lil higher compression n should sleeve ur block cuz wants u go turbo its like crack u want more n more out of it..
Old Nov 7, 2011 | 06:35 PM
SR20?'s Avatar
I think the next step up is 9.1:1. And I may just get a cometic headgasket for insurance. Depends on my funds. Sleeves are way out of the question, though lol
Old Nov 7, 2011 | 06:37 PM
Schister66's Avatar
Man U FTW
If you're only building for 350whp, running a higher static compression will make the car much more streetable. There wont be such a disparity between on and off-boost. If this was my car, i'd consider mid-to-high 9's for pump gas. If E85 is your fuel of choice, mid to upper 10s...
qqhorus
Jan 18, 2013 11:22 AM
Annihilator
Aug 7, 2008 09:08 PM
laziebun
Nov 4, 2007 04:57 PM
JoePSI
Apr 19, 2007 09:50 AM
ranta18
Mar 13, 2004 09:58 PM
