Oil line quick 2 questions
Old Mar 11, 2016 | 09:02 PM
barraea's Avatar
Default Oil line quick 2 questions
Hey all
Sorry for time wasting thread but I'll make it quick
I'm wondering would this oil line kit fit a gt35 wastegate version cheap ebay turbo
http://www.ebay.com.au/itm/141786896023?ru=http%3A%2F%2Fwww.ebay.com.au%2Fsch %2Fi.html%3FisNewKw%3D1%26isRefine%3Dtrue%26mfs%3D GOCLK%26acimp%3D0%26sqp%3D141786896023%26_nkw%3D14 1786896023%26_rdc%3D1
And also an4 as it says the feed line is.. will that fit in to a 1/8npt oil pressure t piece that I've got in the block
Thank you in advance only making thread to be sure
Old Mar 12, 2016 | 05:21 AM
TravisBiggie's Avatar
Default Re: Oil line quick 2 questions
it works, but not well. two major problems with this kit.
1. You never want to use brass fittings directly into an engine block, they break and can **** your engine, just saw a thread where a guy had this problem..
2. That feed flange in my opinion gives more variable to leaking, since it requires a gasket, I hated mine and will never use one again. You're better off buying just a fitting and directly installing it into your turbo oil feed hole (it should be 1/8 npt thread, standard)
Old Mar 12, 2016 | 05:22 AM
https://honda-tech.com/forced-induct...fd-up-3270697/
^^ dudes thread about brass fitting breaking
Old Mar 12, 2016 | 05:51 AM
barraea's Avatar
Ok number one my fault I'll be using a brass t piece adaptor a aeroflow one i believe looked in to it more and found the one i need
2.
This kit doing research all day the feed is an4 which is the equivalent to 1/8 npt but adaptors are only $3 that I'll use one to go into the t piece and into the turbo eliminating the need to use that gasket leak prone flange
Also it says oil restrictior but no spec on size its 2mm i believe for journal bearing turbos i think
I think i might go with this kit just hope i can get a few thousand miles outta it at least
Any other problems you see in this set up ?
Old Mar 12, 2016 | 01:41 PM
2kdrift's Avatar
this is what you get on ebay junk, even when specs are given they are often innacurate
$45 USD for a piece of junk? cough up another $20 and you can actually get a legit feed kit IMO
MBlake55
Apr 9, 2007 01:18 PM
DIYMIKE
Jan 24, 2006 05:14 PM
mattEG
Aug 30, 2004 08:38 AM
toolowsol
Aug 7, 2004 06:17 PM
Tofurky
Dec 12, 2002 03:42 PM
