Fitting for oil feed will not fit.
Old Dec 12, 2002 | 01:54 PM
Tofurky's Avatar
Default Fitting for oil feed will not fit.
(the oil feed is the skinnier line, right? I'm talking about the skinner line)
Well I purchased a maxrev kit from 2K teg...
garret t3/t4
the option was: stainless steel oil lines
i guess i just assumed that it would come with everything i needed for the oil supply..
and the closest fitting earls fitting I am suppoed to use is too small to just thread into it, is there supposed to be an adapter/flange, like one on the oil return line on the turbo? that would make more sense...
if so, where can I get this piece? it's pretty much the only thing holding me up
and does anyone know the thread size
Old Dec 12, 2002 | 01:59 PM
Smashback's Avatar
Default Re: Fitting for oil feed will not fit. (Ruckus138)
The turbo inlet flange should be 1/8" NPT if I remember correctly...maybe yours has a 1/4" and that's why the fitting won't work?
Old Dec 12, 2002 | 02:06 PM
Tofurky's Avatar
Default Re: Fitting for oil feed will not fit. (Hatchblack)
can i just pick something up from OSH or pepboys? and should I use tefflon or no?
Old Dec 12, 2002 | 02:44 PM
HXMan's Avatar
I used teflon paste on mine.....don't use teflon tape.
Old Dec 12, 2002 | 03:42 PM
Full-Race Geoff's Avatar
many of the garrett turbos are 1/4" NPT inlets. the best/easiest thign to do is to head over to pepboys or a hardware store and get a brass 1/4" NPT male to 1/8" NPT female fitting and you will be all set! good luck
88da3
Feb 1, 2006 03:47 PM
oz`Vtec
Jun 9, 2004 07:26 AM
harryg
Sep 10, 2003 07:21 PM
sk8rmike
Jul 22, 2003 07:54 PM
Acura_I-RS
Mar 9, 2003 09:59 PM
