Speedo/Vtec not working.
Old Mar 11, 2016 | 04:58 PM
DohcVtec77's Avatar
Default Speedo/Vtec not working.
So I have a 97 ex coupe with a b16a2 swap in it.. The speedo stays at 20 mph or jumps around sometimes I have no check engine light at all until I try to go over 5500 rpm which is vtec engagement.. Also I just replaced the speed sensor in the transmission because I thought it was that.. any help would be appreciated
Old Mar 11, 2016 | 05:47 PM
DohcVtec77's Avatar
Default Re: Speedo/Vtec not working.
bump
Old Mar 11, 2016 | 06:52 PM
Former User's Avatar
Give details about how you did the swap.
Also, post the CEL codes and the ECU code.
Old Mar 13, 2016 | 02:55 PM
DohcVtec77's Avatar
I just picked the car up from a guy who knew nothing about it pretty much I got it pretty cheap I was looking for a project
Old Mar 13, 2016 | 03:29 PM
mk378's Avatar
Does the odometer roll steady and accurately? If so the problem must be the speedometer head itself, since both functions use the same sensor and wiring.
chrisquin23
Jul 19, 2010 08:44 PM
got00rice
44
Dec 8, 2009 02:54 PM
jaydm ferio
11
Dec 13, 2004 07:19 PM
psycho_civic
Oct 23, 2003 08:33 AM
mattt
Nov 26, 2002 08:03 PM
